![]() | Home > Technical > Joining 1984 fuel tank to Puma gauge |
Could you not fit a puma rear fuel tank and sender? You would have to adjust the mounts, but it should fit fine between the chassis rails.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6683 ![]() ![]() ![]() |
What year Puma instruments?
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 153 ![]() ![]() ![]() |
2007 I think they are.
That's one option I'd not thought about but sounds fairly involved. I'm hoping there's a 'electronic' fix I can do ![]() |
Ok well how about this then;
https://sites.google.com/site/shannonpower...fuel-gauge ![]() |
Can you measure the "full" and "empty" resistance of your sender?
Thanks for sharing ![]() |
I guess so using my multimeter. I'm thinking if I got the same info from a puma sender, I could follow the guide from Geobloke but with a bit more know how? |
2.4 Puma is the same as a Tdi and Td5. Haven't measured a V8 or petrol sender so can't advise without measurements
Learn something everyday ![]() |
So if I can fit a TDi sender in my tank which might be a little easier rather than try the TDCi one, it will be accurate on the gauge?? EBAY here I come.......... ![]() |
In theory yes - my side tank sender (1988 TD) works the Puma gauges nicely, same as the rear tank sender (Td5).
However, get a multimeter on your existing one to see what's going on with the Ohms first. ![]() ![]() |
