Home > eBay & Bargain Spots > 1984 Factory Soft Top.
Slideywindows
First time I've seen another Sept '84 factory soft top like mine (except this is a diesel) on eBay.
It's no looker and its MOT history is chequered, but it's reasonably cheap and might (ought to) sell even cheaper.
https://www.ebay.co.uk/itm/Landrover-Defen...SwJGdbtgSr
Could be a punt, instead of scratching your nice new Defender on a green lane, or converting it to a soft top?
Post #733381 6th Oct 2018 9:37pm
JeremyJ
I don’t think it’s a factory soft top, has had a rear door at some stage, evidence the tie down points are added later (rivets not painted), I’m fairly confident she started life as a hard top
Post #733394 6th Oct 2018 10:24pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Well worth it with a rebuilt 300tdi in it
Post #733395 6th Oct 2018 10:59pm
VVS210
Would tend to agree with Jeremy on that point, but not necessarily because the rivets aren't painted but because of the pair of holes for the lower hinge. This is the second time this has popped up on eBay that I have seen & there is a lot of work needed to get it in a reasonable condition - bulkhead is shot, corrosion evident in body panels as well as doors, chassis probably not much better although ad says it has had a lot replaced in the last 10 years, evidence of bodging from the snorkel to the chequer plate on the bulkhead, etc. Personally I'd swerve this one, there are better examples out there.
Post #733414 7th Oct 2018 8:30am
Slideywindows
Thanks for the input gentlemen. Thumbs Up
So I'm still looking for another 1984 factory soft top. Laughing
Post #733422 7th Oct 2018 10:19am
JeremyJ
To be honest, I don’t think I’ve ever seen a factory one (that’s not military anyway) or much later.
Post #733499 7th Oct 2018 7:08pm
Slideywindows
Well I actually washed mine today. Was so surprised to see it clean that I took a picture. Rolling with laughter
I think you've seen mine before Jeremy. Sept '84, 2.25 petrol soft top from new I believe, as there are no marks or holes for anything else to have been fitted.(I've had two rivet counters inspect it! Laughing )
The son of the first owner said his dad bought it to tow a boat to the South of France, hence the soft top, comfy County seats and repeaters in the front wings for those French motorways.
Post #733531 7th Oct 2018 9:43pm
edo
Re: 1984 Factory Soft Top.
Oh dear.
Date tested
12 December 2017
PASS
Mileage
132,542 miles
MOT test number
9558 4298 9799
Expiry date
11 December 2018
Advisory notice item(s)
Offside Rear Direction indicator slightly discoloured (1.4.A.2f)
Nearside Front Direction indicator slightly discoloured (1.4.A.2f)
Nearside Front Seat belt damaged but not affecting the operation of the belt (5.2.2a)
Offside Front Seat belt damaged but not affecting the operation of the belt (5.2.2a)
Steering box has a slight oil leak (2.2.D.2e)
Nearside Front Track rod end ball joint has slight play rear (2.2.B.1f)
Oil leak ()
Offside Front Radius arm rubber bush deteriorated but not resulting in excessive movement both front bushes (2.4.G.2)
Nearside Rear Rear wheel bearing has slight play (2.6.2)
Offside Rear Rear wheel bearing has slight play (2.6.2)
Nearside Body has slight corrosion floor (6.1.B.2)
Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Date tested
11 December 2017
FAIL
Mileage
132,542 miles
MOT test number
4388 2015 4010
Reason(s) for failure
Exhaust has a major leak of exhaust gases tail pipe (7.1.2)
Offside Front Ball joint dust cover damaged, but preventing the ingress of dirt drop arm (2.2.C.1c)
Oil leak ()
Date tested
5 July 2016
PASS
Mileage
129,253 miles
MOT test number
5463 2291 4857
Expiry date
4 July 2017
Date tested
1 July 2016
FAIL
Mileage
129,253 miles
MOT test number
9270 6340 5949
Centre Exhaust system not adequately supported (7.1.1)
Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Headlamp aim too low (1.Cool
Post #733533 7th Oct 2018 9:54pm
