![]() | Home > Technical > Uprated exhaust studs |
| razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403
Found some on eBay , wurth unrated for 15 quid , bonus
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654
Spot on. Google how to get them out it's all over the internet 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
My method was spraying with plus gas twice daily for a week. Then ran the engine for 15 mins before I tried to remove them, slowly and carefully. None snapped
Cheers dudes , stud one was easy. Stud two is naughty , will take me time , using a heat gun and spray
Click image to enlarge |
| derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 570
Might as well reseal that bung while the manifold is off, will save stripping again in the future to cure a coolant leak.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Sure will fella , good idea is that |
So , while I wait for me new cobalt drill bits and 8mm tap to arrive later this week , I thought i’d try an exhaust stud that had not snapped , put a nut on , welded it into place , left it to cool , sprayed some magic stuff and it snapped off , hardly any force to , so I just gonna spray , spray n spray . Don’t fancy drilling all the studs, but if u have to I’ll have too.
| Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 732
I found a useful thing to get snapped studs out was left-handed drill bits. With the drill in reverse they quite often catch and unscrew the stud whilst you are drilling it out. A couple did require a stud extractor but all came out ok in the end.
Word of warning - your local hardware shop will give you funny looks and ask if you want some tartan paint to go with the drill bits but they doe exist. Think mine came from ebay. 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
All out except the two original snapped ones , they now have a 4mm hole drilled thru , I have a variety of drill bits on the way , including left hand ones . Got a 6.8mm bit coming and a brand new 8mm tap too , just in case
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
With the snapped ones, wind them in, then clean/tap the tread down to the stud, THEN wind them out. That’s how I found it best with the ones I’ve done.
Andy. |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
Is that a dent in the oil filter
The oil filter is dented to match the panels
| All times are GMT |
