Home > Puma (Tdci) > Removing tow bracket
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
This might be a stupid question but does anyone have a drawing or know exactly how the standard tow bracket and all the fixings comes off? I want to get the whole thing including all the top angle bracket shot blasted, metal sprayed and powder coated. It looks like the majority of the bolts into the crossmember must have captive nuts as I can’t see any exit holes. I don’t want to start undoing bolts to find some aren’t captive and then have a half on half off useless tow bar!
Post #733177 5th Oct 2018 8:53pm
Martin
Site Admin
Dig out the fitting instructions and start at the end Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #733184 5th Oct 2018 9:18pm
NickMc
Yep all the bolts that it goes into on a Tdci are captive on a Tdci. Soak them in something for a few days before you attempt it, if you snap one it can be a real swearing match Whistle On some drop plates you need a thinner wall socket to get the main bolts out as they’re close to the edges.
Three along the bottom.
Post #733190 5th Oct 2018 9:40pm
Pinky
Thanks, does that include the ones that go up from beneath, the ones that hold the angle iron on?
Sorry, just re-read your post and you already explained! Not sure why you would need a thinner socket all are in an accessible place as far as I can see!
Post #733193 5th Oct 2018 9:49pm
NickMc
If you have a Dixon bate style drop hitch the bolt head is very close to the uprights on the slider.
Post #733198 5th Oct 2018 10:25pm
Pinky
Oh, I see, I don’t, so no problem! Thanks again.
Post #733202 5th Oct 2018 10:35pm
