Home > Technical > 300tdi Hub Rebuild - Swivels, Bearing, Brakes
domm786
Scotland 1994 Defender 90 300 Tdi CSW Keswick Green
Hello All,
Im going to be stripping and rebuilding the hubs soon on all wheels (1994 300tdi Def 90)- front swivel seals, wheel bearings, brake pads, brake discs.
Im aware i need a 52mm Socket for the hub nuts - got that.
I believe the caliper securing bolts are - 13mm Bihex ?
Brake Disc to Main hub bolts - I think 14mm Spline Head or Bihex? this is the one i need clarity on. Im refitting with new bolts and so its important i get the right socket and not just 'one that fits' .
Swivel ball to axle bolts - I think standard socket will get these? Im having trouble finding the PN to replace these bolts so any help would be appreciated.
Starting this job next week. wish me luck Rolling with laughter
Post #733157 5th Oct 2018 7:23pm
dailysleaze
Swivel to axle bolts are these https://www.landroverworkshop.com/diagrams...s_52600#10 you need to use a ring spanner as sockets don't fit
The brake disc bolts are 14mm bihex
It's a fairly straightforward job. The only thing that can go wrong is setting the swivel preload, so take your time.
Post #733161 5th Oct 2018 7:27pm
domm786
thanks for that info!
yes the job seems straightforward its just trying to clarify some of the conflicting info ive been given regarding bolt head types. ill get a set of bihex sockets. Very Happy
regarding swivel preload, there also seems to be lots of different figures floating about. haynes says 3.6-4.5kg but that looks like on the bench. and not in situ figure
Post #733164 5th Oct 2018 7:41pm
under_rover
2002 Defender 110 Td5 SW Oslo Blue
Here's a copy of the figures I used lifted straight from the workshop manual Thumbs Up
Just redone mine as part of the rebuild project and was straightforward enough. Make sure you've a good selection of shims to go at though, I ended up using a few more than I originally ordered. The figure quoted is with no seals fitted
Post #733265 6th Oct 2018 10:35am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
As you can see you will need a spring balance. Let us know if you can find a reasonably priced one.
Post #733291 6th Oct 2018 12:13pm
Retroanaconda
Every fishing tackle shop carries them, they’re not expensive.
Post #733310 6th Oct 2018 1:33pm
domm786
Thanks for the info. i'll ignore the haynes manual and stick with the workshop figures for the preload.
I managed to get a spring balance from a fishing friend Very Happy
Do the top and bottom swivel bearing get greased when they go in or is oil recommended for these?
Post #733488 7th Oct 2018 6:25pm
under_rover
I used a fishing spring balance Thumbs Up ... Packed mine with bearing grease
Post #733491 7th Oct 2018 6:47pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
For the swivel housing to axle bolts I have sacrificed a 14mm ring spanner and cut the ring in half, as this enables you to rotate the bolts even when they tight, it saves you getting the full ring spanner stuck. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #733521 7th Oct 2018 8:50pm
domm786
how did the ring spanner get stuck?
once you unscrew the bolt enough you can slid the spanner down the threads and remove the bolt along with the spanner?
Post #733534 7th Oct 2018 10:00pm
Mash
The wagons I work on tend to of been washed in salt water so the washers weld themselves to the bolt heads, the cut down ring also allows you to put the bolts back in easier on reassembley as the can sometimes be too tight to do by hand. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #733551 7th Oct 2018 11:24pm
