![]() | Home > Maintenance & Modifications > Heated seat wiring advice |
Two elements perhaps? 12v feed for either...!
Have you got a multimeter to test the circuits? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6712 ![]() ![]() ![]() |
Waeco heatter kit?
They are two stage/heat levels controlled by the Waeco 3 way switch (off-low-high) ![]() ![]() |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 848 ![]() ![]() |
Not sure the make it’s in an exmoor seat but I think they have been retrofitted
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
Earth, low and high.
Two choices, as suggested a two way switch for pre heat and constant. Or, wire to constant only like I did and have a 1 way factory on-off switch. To save you messing, I can check mine to let you know wire colour? If so, drop me a pm to remind me and I'll take a look for you. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thanks everyone
Cheers Steve pm incoming |
