![]() | Home > Technical > New Key |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20879 ![]() ![]() |
Have you tried pressing it multiple times fast and repeatedly? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
Tried that, I will give it another go but think the fob has been flat for some time.
*i have the new style fob with the silver bit down the side. |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Going from memory, I think you have to put the key in the ignition, turn to position II, turn off and then press the fob lock button 4 times.
Still no luck 😐
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6672 ![]() ![]() ![]() |
2015 handbook doesn't mention any procedure to re-pair the later style fob
I had a look in my hand book and as you say there is no procedure.
I had one of the keys replaced some time ago by the dealer and I wonder if they removed both fobs and just added 1 back |
Worth double checking that you have the battery in the right way, and also perhaps trying another battery too.
Hope you don't have to pay Dealer to reprogram. |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Remove the battery from the fob... hold down the lock or unlock button for 10 seconds.
Refit battery and then press the lock or unlock button 5 or 6 times and it should 'resync' Worth a try before visiting a dealer or a good independent that has the kit for the later alarm set up. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Just changed the battery in one of my fobs, and it was utterly unresponsive after.
Took battery out and followed Ian's advice above. With battery out, 10 sec press on a button, new battery in then pressed lock 6 times. Got a horn fanfare (...) as the door was open, then did a little dance. ![]() ![]() |
Ha...
One of my first posts on here for quite a while... and I fix the site owners Defender lol. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
