![]() | Home > Puma (Tdci) > steering splines |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Probably 48,but if I were you I would remove the wheel and count them. You should know what the landrover production line was like.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
you don't need to remove the wheel to count. Pull off the centre pad and count the splines by feel with a screwdriver/paperclip/toothpick/whatever. You can do this with the nut still in place. Don't even need to be particularly accurate - if you count more than 36 then it's a 48 spline!
edo Member Since: 20 Aug 2018 Location: Devon Posts: 379 ![]() ![]() |
This is very useful.
http://www.web-rover.co.uk/articles-steeringwheels.html |
Useful but not definitive!
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671 ![]() ![]() ![]() |
10 mins ago, before I read this, I just ordered a Optimill steering wheel boss... 48 spline.
Having seen this post, just checked, and mine (2011) is actually 48-spline. I know all later Pumas like ours are supposed to be 48...Best to check tho (as hank says) I guess... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 3rd Oct 2018 9:40am. Edited 1 time in total |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
You try being definitive with this topic.... I've done my best!
Haha "Land Rover" and "definitive" can never be synonymous!!
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
It literally takes less than a minute to remove the wheel... Best to check...
Only advice is leave the nut on a few turns before you 'shock' the wheel off so it doesn't come flying toward your face ![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
C90 Member Since: 19 Nov 2024 Location: East Posts: 54 ![]() ![]() |
I have been crawling the internet all week to find the answer to this question for my 2007 90, I had convinced myself without doubt that it was 48 then read a few things this morning that have changed my mind! So I have no clue now. haha.
So... using the excellent advice from you fellas on here... I am going to bump the wheel off and count them! I'll let you know my findings. |
No need to take the wheel off! > 110 XS Double Cab |
I missed your original comment Hank, thanks for that!
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 262 ![]() ![]() ![]() |
There are also different spline thicknesses, which I found out the hard way. My 2009 48 is “thicker” than a 48 for an earlier Defender.
Finally got around to counting the splines, my 2007 90 Station Wagon is 36 splines if it helps anyone in the future as a guide but I do echo the comments above. You can just loosen the nut enough to see them, get a pin and click around the splines to count. This is very easy and well worth doing.
