Home > Td5 > Electric Cooling Water pump
Duke851
United Kingdom 1999 Defender 110 2.5 TD CSW Bonatti Grey
Hello
Has anyone fitted an electric cooling water pump system like the Davies and Craig system?
From the reports I've read, it will allow the engine to operate at the right temperature from start up quicker and the system only works at a flow the engine requires at that moment, hopefully improving mpg by not having the constant drag for the mechanical water pump.
Any ideas?
Post #732444 2nd Oct 2018 12:51pm
jst
there was plenty on this a while back, personally i wouldnt fit one. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #732449 2nd Oct 2018 1:46pm
Duke851
Thanks, James.
I did a search but didn't find out anything, will try again later.
Post #732453 2nd Oct 2018 1:52pm
jst
think it was on a 300tdi, will look later. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #732455 2nd Oct 2018 1:59pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Would the heater still work?? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #732603 2nd Oct 2018 9:51pm
Duke851
Hi
Yes it should, if the pump is not running, then convection current flow should still flow to the heater because it will be cooler than the engine and the cold air flowing past the heater element should also help.
I think........
Post #732605 2nd Oct 2018 9:58pm
ajps72
2001 Defender 110 Td5 SW Chawton White
If you are looking at improving mpg, then electric fan should be the first change, that uses more power than the electric pump.
I do like the idea of heating using the residual heat from the engine. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #732607 2nd Oct 2018 10:15pm
Duke851
Hello Augusto
I will need to remove and fit an electric fan which will improve the mpg, the electric water pump controller will also switch the fans on.
Many thanks
Post #732613 2nd Oct 2018 10:32pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Easiest way to improve MPG is change Defender for another car. Improvement like electric cooling pump will make the car less reliable. Standard proper working fan has nearly no influence on engine - with running engine it is just barely rotating - it is possible to stop it with a finger. If not, than it is stuck and needs replacement. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #732628 3rd Oct 2018 6:34am
Duke851
Hello MadTom
Like everyone here, I choose to drive a Defender at every opportunity and have always wondered how can I improve my defender.
An electric water pump should be reliable, after all the heater motor and cooling fans are electric and I've never had to replace either of them on any of my cars.
Post #732732 3rd Oct 2018 3:00pm
Duke851
Many thanks for your comments.
Very Happy Very Happy Very Happy
Post #732733 3rd Oct 2018 3:00pm
MadTom
Failure of heater fan = no heating, but not cooked engine.
Cooling fan - standard are belt driven, electric powered is the fan for A/C, failure of A/C fan = no A/C or lower A/C power, but not cooked engine, failure of cooling fan (belt driven) = probably big problem like broken belt or punctured water cooler.
Broken electric water pump - probably cooked engine, or at least towing the car home.
In average temperatures, it is not a problem, but my experience with using heavy Discovery od Defender with TD5 engine and travelling into mountains of south Europe in hot summer, the original belt driven fan has huge power, when fully engaged, it is like starting helicopter next to the car. It is not comparable to any "standard" electric powered fan. We had one car with electric fan, and it was not enough, after 2 days of problems with overheating, we managed locally an used belt driven fan, and all was fine. The belt driven fan is kicking only occasionally, but the cooling effect is much bigger when needed. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #732855 4th Oct 2018 8:34am
Duke851
Good Morning MadTom
Many thanks for sharing your experiences with me, it makes a lot of sense.
I am yet to travel that far and in such hot conditions, the last thing I want to do is create a vehicle that does not perform hence asking on a forum.
Post #732870 4th Oct 2018 10:23am
