![]() | Home > Td5 > TD5 - Hybrid / VGT Turbo - Who to buy from? |
I actually do not have experience of either of them, but am interested to hear other peoples experiences.
There are of course other options; IRB, Allisport, BAS, etc that all do versions of the VGT or Hybrid turbos and remap as well. Might be worth firing an email of to them as well. |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
IRB, BAS & allisport all sell the same turbo technics VNT turbo. But allisport also offers a Hybrid from CRturbos (who Jose uses).
Jose is an absolute wizard and will look after you, admittedly he is a little difficult to get hold of. I don't have first hand experience but a friend used him for a remap and was very happy with the results. I have a CRturbo fitted to a TDi and the guys there certainly know their stuff - and its bloody lovely ![]() Just to stir things a little more, there is an Alive turbo in the for sale section ![]() |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1443 ![]() ![]() ![]() |
I have 2 TD5, both tuned by Gary at Alive
![]() I have the PP4, fitted with the Alives own turbo ...... superb. Not tuned for out and out power but just sooooo much more refined and drive able. Its that good the other one will be going for the PP4 as soon as I can justify it ![]() They are also easily contactable as you yourself have said, which continues with the after sales. I have spoke with the other tuners originally, and saw no need to change when I got the second TD5. I even had Garys tune on the 2.2 before I saw the light and went back to the TD5 ![]() |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Alive turbo all the way 👍👍 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 725 ![]() ![]() ![]() |
Thanks for the advice all, I did look at the IRB/BAS turbo and have spoken to Ian at IRB, he's difficult to get hold of and BAS is quite a distance from me. Similarly Td5 inside seem to get good feedback and they travel to you to map the vehicle, their pricing is very competitive as well but difficult to get hold of.
Having spoken with Alive quite a bit it's likely I will go with their product, they are only an hour away or so and will set everything up on a rolling road. Garry seems really helpful and happy to answer as many stupid questions as I ask. Barbel Jim - did you go for their exhaust also? I've currently got a decat downpipe with a straight through mid-box and wondering if it's worth the money for potentially small gains. How is it noise-wise? Currently the 110 sounds nice but I don't want it to be ASBO noisy. Thanks, Harry 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
I was going with there exhaust originally, but there dcat is just that, so I went with Allisport and the dummy dcat, center bullet silencer and standard back box, same as the green one. Its not the loudest and on a motorway you don't get the constant annoying drone. Alives Hybrid turbos are unique to them....... and I traveled over 2 hours .... and particularly enjoyed the journey home
So what is the difference between Alives Turbos and the rest?
Its a hybrid, developed by themselves with some cleaver internals
Thanks for the reply and also your PM Jim
![]() Geobloke - my understanding is that the BAS/IRB offering is a VGT whereas the Alive version is not but stand to be corrected. There's a bit of info here if that helps http://www.defender2.net/forum/post351204.html 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Ahhh so a hybrid version of the GT20 turbo as opposed to a variable geometry turbo. Impressive figures from that 2014 thread started by Alive. Would love to know more about the hybrid in particular whether the exhaust-side compressor turbine has also been upgraded as well. Loads of advertising for the intake turbines being billeted and upgraded bearings, but nothing about the dirty-side turbine. Also, what are the differences between the Alive hybrid and the Allisport hybrid because apart from a fancy coat of paint on the Allisport version they look to be quite similar, apart from price that is... So many questions. |
Remember that the Allisport turbo has a surcharge of £400 so will put the pricing in line with Alive's offering.
Both the turbos will look the same externally as they are both a standard TD5 unit, its what's inside that counts, which will be a machined housing and different turbine and compressor. The information of the uprated wheels, neither company is likely to divulge. I think that Alive and TD5inside/CRturbos are both reputable companies and deliver good results, if it was me having the tuning done I would match the turbo to the tuner. Have to say, I have the Alive exhaust and it is delicious ![]() |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Could someone aluminium me in regards to VGT/ hybrid?
I know a VGT will change its fan blades angle of attack to get the most efficient compression just like a prop plane, but how does a hybrid work? Is it just tuned in a way that gives better compression at low engine RPM but less at higher RPM? Is it like the atlas turboprop props? I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
A hybrid turbo is just a fancy way of saying that the moving parts have been upgraded, so the main turbo housing remains the same as standard but the internals are no longer standard;
billet compressor will possibly have a different number of vanes, vane pitch/curvature and blade roughness - designed to gather air more efficiently. The importance of the billet aluminium is that the manufacture and balancing can be done to a very high precision. Relatively easily and cheaply. But as mentioned before I wonder whether there are any changes to the exhaust-side turbine or is it that since you cannot see the turbine it is not worth mentioning. I suspect that if it had been up-rated it would have been advertised, but I am a curious chap who likes to know and understand. |
lets just say the exhaust side isn't standard
