![]() | Home > Puma (Tdci) > Bonnet gap |
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153
How much of a gap should there be guys? On my USW the bonnet sits quite tight along the wings, but there is about 3/4 of an inch gap above the grille panel - enough to see the spring and latch mechanism. I thought the bonnet wasn't shut properly but that is as far as it will go. Its an aircon grille if that makes any difference - what kind of gap should there be?
Cheers. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
It can't come any further down as then it would be compressing the wings.
Maybe it just shows up cos of the contrast with the silver bits and the green body, which wouldn't be so obvious on yours... 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
The gap on my 90XS is 1 cm under the R of Land Rover, with an even gap along wings.
Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Looks about the same as mine then. Maybe I am just expecting too much progress for the poor old Defender...
| 110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444
I'd measure mine but my tape measure doesn't go that far.
(for the bonnet gap that is) I have a/c and same issue. Shut properly. Perhaps it's a design feature: additional air cooling. |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Thats normal they are built by brummies you know
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18052
They do say that there are only two man-made things that can be seen from space -- the great wall of China, and the panel gaps on a Defender.
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363
And the Glasgow Celtic away strip?? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
| Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 354
It's great - with Defenders you never will find two the same
Ex RR Sport HST V8 Ex Td5 90 |
| LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241
We will be living on Mars and still love and talk about them. 90 V8 SOFT TOP |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219
Funny you should say that..... years back I shoehorned a 3.9 EFI into my old 90, which always ran hot, even with a big TD radiator (that's why I love diesels!) anyway, for extra cooling i wound those front screws right down so the bonnet sat up slightly with a large gap at the front. It did help cooling a bit. |
| NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397
Quite interesting, I guess the gap is some kind of mud eater option?
| All times are GMT |
