Home > Technical > a dash that is driving me crazy
Page 2 of 2 <12
rillas
Australia 2003 Defender 90 Td5 HT Tonga Green
thanks all for the comments the short video hit it on the head thinh I will go and buy a set off ear muffs
Post #730487 22nd Sep 2018 1:03pm
Martin - Is there a fixing present there just below your hand in the video? Looks like a recess for one and pretty sure mine has one. A screw much like the dash top torx head. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #730533 22nd Sep 2018 7:17pm
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
+1 for the bonnet hinges. Mine were the same on the Puma. The little nylon inserts were the culprit. I didn’t even to buy new ones I just swapped them over and this cured it. Take the bonnet off and go for a spin and see if the noise goes.
Make sure you don’t lose the little nylon bits tho Smile
Post #730534 22nd Sep 2018 7:18pm
Martin
Site Admin
Yes where my fingers keep going there is a screw fitted there Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #730535 22nd Sep 2018 7:19pm
yostumpy
Have had tho in the past. Only happened over 50 mph or when going round roundabouts. Took me about 3 years to find it. Turned out the a lump of glass from a broken side window, down the front well of the dash, which flexed on roundabouts, and the bulkhead moved with wind pressure over 50. Run a screwdriver or bent bicycle spoke along the well, and see it anything flicks up, a screw maybe?
Post #731935 30th Sep 2018 8:28am
rillas
Thanks I will look in the morning
Post #731950 30th Sep 2018 10:40am
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Rkcorry wrote:
Anyone remember this one.
She looks a lot like Sean Young in Blade Runner... which is no bad thing!
Post #731963 30th Sep 2018 12:00pm
Martin
Site Admin
YES!
Fixed my squeak completely.
Two contributing factors: centre screw fixing and radio cage.
The dealership technician had refitted the centre topmost screw (the one my fingers were on in the vid) at an angle, missing the plastic lokut nut and giving a poor fixing.
Also, they had evidently removed the radio as part of the warranty work, but did made a mess of refitting. The radio cage was loose, and the radio loose in the cage. Oh and the rubber for the locating peg was missing.
So - removed radio, refitted cage securely, found a spare rubber for the rear locating peg. Refitted radio and made sure it was pushed all the way into the cage.
Bingo Mr. Green Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #736877 26th Oct 2018 2:47pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Its a defender, it should squeak, and creak, and clang, and bang?!?!? NO??
Rolling with laughter Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #736879 26th Oct 2018 3:28pm
Martin
Site Admin
Absolute bliss now   1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #736881 26th Oct 2018 3:35pm
rillas
martin thanks pulled radio out replaced panel still there so I left the two srews out went fo drive over rough road no squeck so I put upholstery pins PERFECT no more mouse sorry did not need mouse trap
Post #737764 31st Oct 2018 10:01am
Adam17
I cant imagine what its like to drive a Defender with no rattle - Its weird enough in my wifes corsa - almost too quiet for me now.. Only had my Defender since May, in the beginning all the knocks and bangs were worrying(coming from a pampered Audi with no noise at all) but I love all the noise it makes now! Regards
Adam
Loving The Duchess
Post #737781 31st Oct 2018 11:55am
Page 2 of 2 <12
