Home > Maintenance & Modifications > volt meter and amp meter
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
does any body know where i van get a neat compact digital volt and amp meter to see the effectiveness of my batterys
any one got ont or know of anything
kind regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #72816 25th May 2011 10:10pm
Wizard Sleeve
United Kingdom 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Ive got this one:
http://www.nasamarine.com/proddetail.php?prod=BM1Compact
Works lovely
Post #72826 25th May 2011 11:55pm
big steve
Went and picked one up today nice bit of kit have you got a winch on yours where did you put the shunt ???
Regard steve 2015 2.2 tdci hardtop xs
Post #72922 26th May 2011 4:08pm
Wizard Sleeve
Hi I run a split charging system for my audio and radio stuff vie got my defender. i have a winch but that is connected to my starter battery. The second battery is pulled in via a 300A BEP marine automatic relay. I run the shunt on the Neutral Leg between the two batteries. I have the second battery fused at 100A as the shunt is only Rated at 100A. But if you want to pull winch current through the meter then bigger shunts are available (Any companies work as long as they are the right A/mV output)
http://www.aacix.com/pdf/SR-current%20shunt%20resistor.pdf
Post #73189 28th May 2011 10:48am
Shutts
United Kingdom 1995 Defender 90 300 Tdi SW Arles Blue
Does any one know of a single monitor that can display the state of both batteries?
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
()_)' '()_)-----()_)
2005 D3 SE
1998 Disco 300tdi - slow play thing
1995 Defender 300tdi - Winching play thing
Aprilia RSV 1000 - fast play thing
Honda CR250 - noisy play thing
Essex Land Rover Club member
Andy's Landy's - http://www.andys-landys.blogspot.com
Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip
Post #358632 18th Sep 2014 10:28am
K9F
Simple solution perhaps would be to configure the wiring of the unit above through a simple relay and switch so you could switch between the two batteries to view the status of each in turn. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358640 18th Sep 2014 11:26am
mikeh501
theres an ebay seller who does a 52mm dual digital voltage meter for about £30. Doesnt do amps though.
Post #358760 18th Sep 2014 7:39pm
excossack
If you have room I spotted this on the 'bay
http://www.ebay.co.uk/itm/DC-0-120V-0-50A-...27ec1544f4
not sure if any use? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #358765 18th Sep 2014 7:45pm
Shutts
Thanks guys
A relay would work well and I could connect it via the ignition so it only shows when the key is turned.
Also like the meter on ebay. I have plenty of room on the center dash to fit it.
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #358881 19th Sep 2014 10:10am
