Home > V8 > 50th anniversary exhaust route
oneten110
I just wondered if anybody has a standard 50th anniversary, manual, and if they could tell me the route of the exhaust between manifolds and middle box, particularly the area where it goes over(?) the gearbox X member, please. a photo being worth a thousand words and all that, please?
Post #731693 28th Sep 2018 5:28pm
NAS90
Standard 50ths are all Automatics, the 50th didn't come in manual.
If it helps the 1994 & 1995 NAS Defenders are V8 manual, they have a Y Pipe that comes from the manifolds, run underneath the gearbox crossmember and then come together under the transfer case into a flange that bolts to the rear section silencer (they are LHD though). Link to a photo I found shows a 1995 NAS
https://www.schmitt.com/wp-content/uploads...-90-51.jpg Is there such a thing as too many Defenders?....
NAS90 Soft Top, 50th Anniversary, Spectre 110 Puma,
Ex Italian Police 90 with JE V8 Auto
Post #731703 28th Sep 2018 6:16pm
Romadog
It goes under the cross member.
Must fit cross member first.
Check out video below as it shows the area you require Thumbs Up
Post #731706 28th Sep 2018 6:17pm
oneten110
Thanks for the prompt replies fellas. In the words of the immortal bard, bow locks. won't fit a 110 then
Post #731713 28th Sep 2018 7:03pm
jonny
Not sure what system you have at the moment, or if this is any help, but you can make up something that fits from off the shelf bits...
IIRC its:
3.9 cast manifolds
RRC Y Pipe
110 TD5 / Puma centre / rear section (can be sourced as take offs cheap on ebay)
You need to change one of the centre hangars and possibly fabricate a rear hangar but it all bolts up together.
This is what I've got on mine Smile
Post #731749 28th Sep 2018 8:57pm
Romadog
I don't understand your problem....
I have a 110 with v8 and auto.
Disco1 or RR Classic V8 cross member with easy modification.
I have a 300tdi intermediate pipe and tailpipe on mine
Post #731813 29th Sep 2018 7:46am
oneten110
What is the easy modification to the Xmember, please?
Post #731867 29th Sep 2018 4:30pm
jonny
From what I remember you have to use the Disco / RRC X Member and weld a bit on the bottom to extend the mounts - the defender one is straight, the disco ones are like this:
\____/
the Y pipe fits up in the nooks of the x member
Post #731875 29th Sep 2018 5:58pm
jonny
Help?
Post #731877 29th Sep 2018 6:06pm
oneten110
It is a bit perplexing because at least 2 X members for the discovery have the same part No as the equivalent 110 item.
Post #731891 29th Sep 2018 7:20pm
jonny
Post #731893 29th Sep 2018 7:29pm
oneten110
A thought occurs, does anybody know the part no for the X member on a 50th anniversary, please?
Post #731942 30th Sep 2018 9:26am
oneten110
Found it, eventually, in the NAS 110/90 parts list. NTC9241
Post #732001 30th Sep 2018 5:45pm
Romadog
Good luck on that one...
I got a steel fabricator to weld some plate on each end to mak it square, bolted it in on top bolts, then drilled through holes in lower brackets on chassis and into the cross member, bolts in with plenty of copper slip . All done and on with fitting exhaust Thumbs Up
Post #732044 30th Sep 2018 8:13pm
oneten110
Available from Land Rover, 262 +vat.
Presumably since the same xmember was used on both NAS models 90/110 and the 50th anniversary then at least some of the chassis manufacturers will make them as well.
Post #732054 30th Sep 2018 8:43pm
