Home > Maintenance & Modifications > Door Mirror Arms Floppy
Merlin
My door mirrors became floppy (please no innuendos) so I fitted new ones from Bearmach, but the new ones are floppy. Is there an adjustment? Here is a link:
https://bearmach.com/mirror-arm-long-260mm...a-rrc8443r
Peter
Post #731375 26th Sep 2018 7:02pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Have you tried the blue pill?
Is it the arm or the mirror drooping? If its the mirror just check the rubber washer and tighten the hex screw. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #731381 26th Sep 2018 7:11pm
Merlin
Its where the arm meets the door hinge. I'm mystified.
Peter
Post #731386 26th Sep 2018 7:27pm
OsloBlue
The mounting is drooping or the arm is deforming? I'm on IG: https://www.instagram.com/osloblue42/
Post #731388 26th Sep 2018 7:35pm
Merlin
When you turn the arm to adjust it for how far out it is, the arm clicks over to the position. My one does this but there is a lot of movement back and forth. So it wobbles when moving. Peter
Post #731391 26th Sep 2018 7:42pm
Bps
Is the arm mount tight against the hinge? Mine were flapping about on one side and a bit scabby so I replaced it and found that whatever bolt was in it wasn’t the right one ( should be dome head posi ) which has been overtightened and pulled the threads out of the mirror mount
Post #731397 26th Sep 2018 8:03pm
Mo Murphy
I always helicoil new mirror arms with a M6 coil. It's stronger and a lot less faff !
50 Shades of Pennine Grey
Post #731417 26th Sep 2018 9:38pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I replaced the Land Rover standard arms with the same companies extended arms some years ago. When parking in carparks the arms were folded in so as not to annoy the drivers of adjacent vehicles, after two months the arms just swung about in the breeze and were totally useless, I replaced them with genuine Land Rover extended arms . On comparing the two products it was easy to see why the copy's failed , the spring had no resistance to inline pressure and the material was only half the thickness of the genuine item.
I took the faults up with the company only to be told that the arms were not designed to be folded in.
The current genuine set have last 5 years, with the larger mirror heads and have not showed any sign of deterioration of the spring and still hold firm even when blasted by the pressure wave of oncoming HGV'S. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #731479 27th Sep 2018 11:15am
geobloke
Mo
Complete unrelated to door mirrors, but thank you Mo. I was desperately trying to remember the name "Helicoil"... I would like to use them to repair the thread hole the bolt that fixes the TD5 engine sound proof cover in place. One of those I will get around to it jobs that the vehicle came with.
Thumbs Up Thumbs Up
Post #731480 27th Sep 2018 11:37am
Merlin
Any chance you know the part number for the Land Rover Wolf extended arms? Peter
Post #731488 27th Sep 2018 12:22pm
geobloke wrote:
Mo
Thumbs Up Thumbs Up
You may also want to check out "Timesert" threaded inserts, which are similar but often rather more satisfactory. A Helicoil will probably be quite sufficient for the purpose you mention, although if the holes are shallow and blind (and I can't remember how deep they are for the TD5 acoustic cover) you may need to get hold of a bottoming tap of the appropriate size. Watch out also for the swarf blocking the hole when tapping blind holes.
A job which has been on the "when I get around to it" list for several years now is to fit Timeserts to the holes for the front branch of the exhaust manifold in the head of my 2.4.
Post #731491 27th Sep 2018 12:30pm
ARC99
I got mine from Dan @ Duckworths as all the others advertised were copies. Don't make old people mad.
Richard
Post #731637 28th Sep 2018 11:42am
dorsetsmith
RRC8443
Post #731649 28th Sep 2018 12:46pm
Merlin
Cheers, BTW will standard mirrors fit? Peter
Post #731650 28th Sep 2018 12:48pm
geobloke
blackwolf wrote:
geobloke wrote:
Mo
Thumbs Up Thumbs Up
Never heard of Timeserts so thanks Smile IIRC the hole in the head is threaded only part of the way with a non-threaded void at the rear. So a standard tap should do the job. Have to confess I cannot remember off hand how much material there is to "play with" around the hole...
The other "when I get around to it" job is the captive nut on the fuel heater for the acoustic cover... Not a happy thread in that... Rolling Eyes It is endless...
Post #731651 28th Sep 2018 12:53pm
