Home > Technical > New Coolant Gaue TD5 Defender
bankz5152
Im after a new coolant gauge for my 110, specifically a Stack one to match my boost gauge. Though how do I tap it in? Id rather avoid cutting the top hose if possible.
Anyone changed their coolant gauge on a TD5 before?
Post #731320 26th Sep 2018 1:06pm
geobloke
I gave in and cut the pipework to fit the gauge sensor. I believe there is a modified coolant to head flange that has a position for the standard sensor and a second auxiliary one allowing the ECU and a separate gauge to work.
I will see if I can find it again.
Incidentally not had a problem with the inter-hose sensor since fitting.
Post #731328 26th Sep 2018 1:40pm
geobloke
Here you go - https://goreproducts.com/products/td5-coolant-housing
The only reason I didn’t go this route is that I couldn’t get the part in time so went standard outlet elbow and hose insert.
Post #731339 26th Sep 2018 2:18pm
