![]() | Home > Maintenance & Modifications > Anti roll bar torque figures |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6702 ![]() ![]() ![]() |
Front
Position bushes on stabilizer bar. Ensure split points towards axle on RH bush and away from axle on LH bush. 2. Install stabilizer bar with two straps. To ensure correct fit angled sides of bar should point down. Loosely install the bolts, washers and nyloc nuts. 3. Install bolt, washers and rubber bushes. Using new nuts fit stabilizer bar to links and tighten to 68Nm (50 lbf.ft). 4. Tighten nuts securing straps to 30Nm (22 lbf.ft). Rear Position rubber bushes on stabilizer bar. Install joint towards axle. 2. Install stabilizer bar with two straps. Ensure link arms point down as shown. Loosely install bolts, washers and new nyloc nuts. 3. Install bolt, washers and rubber bushes. Install anti-roll bar to links and tighten to 68Nm (50 lbf.ft). 4. Tighten nuts securing straps to 30Nm (22 lbf.ft) Drop link to axle torque is 40Nm (30 lbf.ft) ![]() ![]() |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2675 ![]() ![]() ![]() |
deleted - Martin beat me to it with a better answer
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7931 ![]() ![]() ![]() |
Noted thanks Martin!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20959 ![]() ![]() |
Thank you all, much appreciated.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Right, I have done the rear today, the rear NS (passenger.) was the culprit with the 2 piece ARB to link bushes.
They were getting worn all of them but this particular one was not concentric and on a skew, pretty sure it happened after hitting a pothole in hidden water. Ideal opportunity to swap all of them out as they aren't that expensive. Replaced the chassis strap fixings but re-used the ARB fixings as these were in very good condition. As were the straps after a clean up. Hopefully get on with the front tomorrow. Thanks once again for the WSM details Martin. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Done the front today as well, this one being a bit more tricky.
Never needed to remove the links at all, access to the OS drivers side fixings were a pain due to the axle casing. But there is just enough movement in the links articulation to get enough access to get the torque wrench on it keeping the ARB as spare to the link as possible. Then access to the NS is much easier then to follow up with. Also, found it easier when tightening the chassis straps to tighten the side without the bush split in first followed by the side without. It will then pull the split nicely together, something that was not quite so good before. Job done. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
