Home > Puma (Tdci) > Stiffen up Door Hinge/Stay
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Anyone any advice on how to stiffen up the door stays on a Puma so that they will stay open but still close easily. Managed it on the back door by putting a Nylon washer on the Door Stay hinge bolt. Now I don't have to open it each time when packing/unpacking the car. However cannot use the same trick on the front. On my last few cars the doors would stay ajar when opened to a certain point but not the Defender. Whistle Whistle
Post #73058 27th May 2011 1:51pm
mse
For me it was just do up the bolts..they were a little loose Mike
Post #73059 27th May 2011 1:52pm
WelshGas
Hi Mike,
Which bolts are you referring to, the hinges or the Stay rod that slides in a channel under the dash?
Post #73061 27th May 2011 2:19pm
mse
it was the stay bolts you can just see it to tighten on the front doors...you will see it move when you open the door Mike
Post #73064 27th May 2011 2:37pm
nickhodgson
I eventually removed the bolts and added some split washers as I was getting tired or always tightening them.
Post #73075 27th May 2011 3:58pm
mattlab
England 2009 Defender 110 Puma 2.4 USW Galway Green
as regards the rear door, mine wouldn`t stay open just pulled bottom left of cover away (dont need to take cover right off) and retightened door stay which is a little arm that locks into the stay as it slides, common problem them coming loose, 2x 10mm nuts, had no probs with front so cant help LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #73077 27th May 2011 4:08pm
mse
its almost the same except you dont have to remove anything Mike
Post #73086 27th May 2011 4:33pm
WelshGas
Front door stays are held to door bracket by a Pin and cotter pin.No way of tightening so removed pin and replaced with Bolt+nylon washer+nyloc nut. Now just enough resistance to hold door open but still shut easily. SWMBO will be happy, always moaning about having to hold door open when getting in. Thanks ALL Bow down Bow down
Post #73093 27th May 2011 4:50pm
LostinOz
Australia 2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Here goes my first post!! Just tightened the rear cargo door and front left today. Both needed tightening as stated in the prior replies. But here is the dig on the cargo door. The pin that clicks into place and holds the door open pushes on the top left corner with some degree of force. It pushes against an under-engineered 'tab' of metal that bends under the weight. So once you tighten the nuts, in some cases the door still does not stay open safely. I bent the offending 'tab' forwards again and then wedged something solid behind it. It is a 3mm x 4mm x whatever length spacer of anything solid. Did the trick. Now the door pin pushes against its 'tab' that is supported with something solid from behind and the door now stays open for the first time since I bought it! I'd taken it back to LR in Sydney and they had said 'performs same as all others', and 'cannot fix'. So I popped off the plastic on the back door (after removing the u-shaped handle) and fixed it in a few minutes. Happy days!
Post #74307 5th Jun 2011 1:19pm
WelshGas
Any pictures LostinOz. Bow down Bow down Bow down
Post #74334 5th Jun 2011 6:52pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
wont need pics .. its easy to see once cover is off, did it to mine about 2 years ago .. not had a problem since Guns and Landrovers .... anything else is irrelevant.
Post #74366 5th Jun 2011 9:40pm
Bill
Ireland 2008 Defender 90 Puma 2.4 XS CSW Java Black
I was going to try and fit a gas shock to the back door. think i'll try your methods first, but has anyone tried this? 08 Puma 90xs
BMW R1150R
KXF250
Keep On Truckin
Post #74434 6th Jun 2011 12:56pm
Naks
Plentym, see http://www.defender2.net/forum/topic6886.h...gas+strut; http://www.defender2.net/forum/topic5494.h...gas+strut; --
Post #74439 6th Jun 2011 1:29pm
Lorryman100
Post #74510 6th Jun 2011 8:00pm
Bill
Plentym, see http://www.defender2.net/forum/topic6886.h...gas+strut; http://www.defender2.net/forum/topic5494.h...t;[/quote]
Nice Wink think i might go down this road. 08 Puma 90xs
BMW R1150R
KXF250
Keep On Truckin
Post #74528 6th Jun 2011 9:02pm
