![]() | Home > Td5 > Clutch master cylinder not enough thread to adjust pedal |
I have no doubt that someone has had the same problem, in fact I am sure I have seen it somewhere on these forums...
Why do manufacturers differ in the amount of thread they cut in to the rod of the clutch master cylinder?? This week my clutch pedal pretty much ceased to function properly making getting in to gears interesting...! So I bought a new master and slave cylinder from Bearmach. Figured both from the same manufacturer would be a good thing. Actually a little peaved as I only replaced these a year or so ago. That time TRW and AP which are meant to be good brands! Looks like the TRW master cylinder has been leaking for quite some time, removed all the paint in its path and caused the footwell to rust badly... ![]() So today I have replaced both cylinders but have not been able to adjust the pedal because there is only just enough thread on the rod to get the nuts on and the pedal is very high... has anyone else found this problem? Is it something I should contact Bearmach about? Or is this one of those they’re all like that sir moments...! Is very odd. On the up side the clutch now works as it should even if the pedal is very high. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
had same problem in past swiped thread rod over
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Yep TRW or nothing here too.
TRW and blue box parts leaked i stick with genuine
Nutter Member Since: 15 Sep 2014 Location: Birchington Posts: 25 ![]() ![]() |
Hi have you tried only putting one nut on the clutch master cylinder side, if you got two will make pedal higher.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
^^^ Agreed... .all mine have had one nut each side of the top of the pedal. tighten them both up so the "other" one can't rattle down the thread.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8314 ![]() ![]() ![]() |
One nut and swap rods if still required Cheers
Based on the TRW part I just took off after 18months or so I would have to agree...! So annoyed with the damage the leak has done. |
No. Isn’t there meant to be two on the cylinder side to lock them in position so you can set the pedal free play?! Mind you there is so little thread on this rod I’d oubt having only one but wouold matter... |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Nip to Halfords and buy a tap and die set and run up new threads on the rod.
Not ideal, but should give you some more adjustment and get you going quicker than sending bits back. |
Hi you need to adjust your pedal height first on the front of pedal box to 140 mm from floor to bottom of pedal (no mats)
Then adjust push rod so there is 1.5 mm free play between push rod and cylinder piston. one nut on each side of pedal. James |
Ok here is a question: Can you slide the pedal grunion off the cylinder rod to remove one of the nuts in-situ?
I suspect the answer is no, but kinda hoping... |
Hi James. Thanks. The problem is there is not enough thread on the rod to get the pedal anywhere near the requisite 140mm. ![]() |
Did you buy a genuine TRW at £££? There was someone on an auction site selling TRW cheap and not TRW. You’d be surprised Eurocrap parts got duped a few years ago and bought a lot of fake LUK clutches for example ![]() |
