![]() | Home > Technical > a dash that is driving me crazy |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
Lubricate the bonnet hinges. A common noise that you would bet was coming from the dash area. Try them first.
| rillas Member Since: 27 May 2012 Location: warilla nsw 2528 Posts: 16
thanks i will do in the morning
Forgot to add, if that doesn't work check the bolts that hold the roof on especially the screws in the corners which have a habit of working loose.
| edo Member Since: 20 Aug 2018 Location: Devon Posts: 379
Click image to enlarge |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
| Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 227 |
Anyone remember this one.
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141
Place a cat inside your dash, then a dog, then a duck etc. etc. E-I-E-I-O
| Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 951
I remember that vw advert! Was only 8 in 1990!!
| mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605
I've got a pair! The sound cancelling is flipping amazing. So good, some pilots use the aviation version that has a mic! ... now.. imagine an intercom system in a defender |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11094
I have got a pair as well and they are .......... amazing 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I suspect we're not helping much
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
Check the wiper motor is secure on it's bracket (Access via the speaker hole)
Check the engine ECU is tight in it's bracket, the bottom of it is just some foam wrapped around it and jammed into a slot, the foam wears then develops into a knocking. |
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
I would start with the basics and check all the dash fixings for tightness. The dash could be just loose and rubbing on the body.
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
I've got a similar problem ever since it went into the dealer last winter
I've released and tightened everything and it is still rubbing/squeaking in the middle. Massively irritating as it was genuinely squeak and rattle free before 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| All times are GMT |
