![]() | Home > Td5 > Looks like I’m going to be busy on Saturday! |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Sister rings me, (She has a Td5 90 same as me)
‘When I accelerate with the horse trailer on, the revs go up but when I let off it goes back to normal” Went and had a look clutch is slipping, no oil leak into bell housing just worn out, so yesterday rang L.O.f clutches up and ordered a power spec clutch and new flywheel. And today it arrived, clutch comes with new spigot bush, bush for clutch fork, and improved wire release bearing retainer. ![]() Click image to enlarge Looking forward to getting this fitted on Saturday to see if there is any difference in feel, it is said to have a similar feel to a standard clutch. I’m not in anyway connected just pleased with the advice and service from LOF and will update on the outcome when fitted. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Very much interested in this.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3259 ![]() ![]() |
Well they are certainly good units, OE on BMW
