Home > Td5 > Which springs?
lightning
Which springs?
Are TD5 and TDCi springs different? I thought the TDCi springs were progressive to give a better ride quality?
I have been offered a new take off set from a 110 2.2 SW but the seller says they are “no different” to the TD5 ones.
He says the TDCi appears to ride better due to it being generally more refined with more sound proofing and a better gearbox.
Post #730098 20th Sep 2018 10:57am
geobloke
What colours are painted on the springs?
The TD5 110 CSW came with;
Front - White/White Nearside and Yellow/Yellow Offside progressive rated at 155/215 lbft
Rears - Both Purple/Brown progressive rated at 270/420lbft
These make a hellofa difference over the single rated LR springs used on earlier models and non-station wagon models.
This is a great resource for spring specs: http://www.red90.ca/rovers/springinfo.html
I have since upgrade to Old Man Emu springs and shocks all round as the weight of the roll cage eliminated the point of the lower rated part of the spring and Miffy sat too low.
Post #730104 20th Sep 2018 11:09am
lightning
Do you know if the TDCi springs were any different?
If my 2005 110 TD5 SW has the same springs as the TDCi there’s no point changing them.
Post #730112 20th Sep 2018 11:58am
geobloke
I agree and no I do not know the answer off hand.
Drop the guy a line and ask what colour coding is on his springs. You can at least rule out them based on that.
Post #730114 20th Sep 2018 12:30pm
geobloke
Actually, I have a vague recollection that the Puma springs are different; longer from memory.
Post #730117 20th Sep 2018 12:32pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I believe that Puma and Td5 110 rear springs are progressive. Which means that one end the coils are more tightly spaced the other end is wider. Variable weight in the vehicle with a better ride overall. Colour codes are correctly posted for the Td5 springs above. That is the best way to tell for sure. If you want a smoother ride install spring isolators from a DII in front and Toyota Tacoma in the rear.
Isolators
Progressive
Regular
 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #730170 20th Sep 2018 4:55pm
lightning
What does it mean “rears purple/brown progressive rated at 270/420 lb ft”
Does that mean there was a normal and a heavy duty option and the heavy duty version had brown paint while the standard spring had purple paint?
I ask as my 110 sits higher at the rear by about 1” than most, l know the previous owner towed a boat with it and l wonder if he fitted heavy duty springs.
Post #730174 20th Sep 2018 5:36pm
geobloke
The 270/420lbft relates to the fact that a portion of the spring is rated to 270lbft and the remainder is red to 420lbft. The theory being that when unloaded the ride is more supple and when carrying 9 people plus baggage the suspension would still hold the body up off the axle.
And it works brilliantly...
Post #730175 20th Sep 2018 5:41pm
lightning
Thanks that’s all really helpful advice and exactly what l wanted to know, so it’s probably not worth replacing my springs.
Post #730218 20th Sep 2018 8:57pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Have you got the part number for the isolators?
Do they fit 110 or 90 because IIRC 110 have bigger/wider rear springs? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #730236 20th Sep 2018 9:43pm
4RF RDS
I’ll look for them for you. The yellow Toyota ones are for the rears. The Dicso II ones are for the front top. You can find that part number easily enough. 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #730255 20th Sep 2018 10:40pm
lightning
I may fit those as well.
I decided to order the springs anyway as they are brand new and only £100 for 4. (from one of the companies who bling up new Defenders)
Mine have done over 100,000 miles and are pretty rusted up.
Post #730319 21st Sep 2018 1:12pm
4RF RDS
The yellow isolators for the rear can be purchased here. http://www.lowrangeoffroad.com/catalogsearch/result/?q=OME80PR10
I also understand Devon 4x4 has them over there in the (mostly) United Queendom Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #730326 21st Sep 2018 2:15pm
lightning
So the springs have arrived from Twisted, they are new take off.
One pair has green and white markings and the other pair have yellow marks, they said the springs were from a TDCi SW.
The yellow/yellow pair appear to be standard 110 front but the green/green/white pair don’t appear on the springs list above.
Anybody know what these are before l fit them?
Post #731825 29th Sep 2018 9:52am
lightning
Ah it seems they are indeed later 110 SW standard rears.
http://www.defender2.net/forum/topic13312.html
Post #731830 29th Sep 2018 10:32am
