![]() | Home > Tdi > EGT Gauge Fitting |
| white110 Member Since: 09 Dec 2017 Location: wales Posts: 10
First thought was EGR blanking plate, drill and thread for adaptor.
How much depth does the sensor require ? |
| jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 368
Jip. That's how mine was done. Then you give the thermocouple a slight bend to put the tip into and upwards into manifold.
| Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 850
This is what I used
Click image to enlarge |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Not a 300tdi but a TD5. I fitted an EGT guage almost a year ago now and i have to say the thing that surprised me the most was just how much the temperature fluctuates and by how much. It is no wonder exhaust manifolds warp or studs break.
Well worth the effort to install. There are some good youtube videos out there IIRC for 300tdi installation. Just search for "300tdi egt gauge" and there is heaps of stuff out there. Which gauge have you found? |
This is what I use. Been reliable for the last 12 months or so
| NAS90Noel Member Since: 02 Nov 2010 Location: Carregal do Sal Posts: 2
Thanks for all the ideas. I've found a gauge here at $160, it's cheaper then I've seen in Europe and is almost a match for the VDO gauges I already have fitted, and comes with sender. VDO gauge plus sender was really expensive option! I've already ordered the EGR plate with 1/8 NPT fitting from fleabay. So looks like I have my next job when I get home. Thanks again for all the assistance, much appreciated. He who wanders is not always lost
Good luck
Which brand of gauge did you go for in the end? |
