![]() | Home > Maintenance & Modifications > Should I weld half shafts to drive flange? |
This was discussed a couple of weeks ago and the consensus was that unless you're a very good welder, you won't get the penetration needed to make a decent job of it.
I've just fitted genuine one piece shafts to mine and they have made a real difference. I did manage to pick them up for a very good price, though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3726 ![]() ![]() ![]() |
Cheers, I have a good mate that is a coded tig welder, so comfortable getting the quality. I guess my other concern is that this is essentially the sacrificial part, so if I make it solid am I not going to make the diff end the sacrificial section?
No. It's only sacrificial because it's not lubricated, which doesn't apply at the other end. Darren
Makes sense, thanks.
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
If you search backlash sorted you'll get to the thread mentioned above, complete with pictures.
