![]() | Home > Td5 > Silicone Hoses and OAT coolant |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Didn't realise there was a problem with silicon and OAT??
I have LR hoses so no issue for me but there are lots of folk on here with silicon hoses ![]() Have you any further info on this? |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 291 ![]() ![]() |
From https://www.lhss.co.uk/silicone-hoses/oat/
So basically, the "blue" silicone hoses you can buy probably aren't OAT compatible, certainly the multi colour ones available from lhss aren't, they're for Etheylene Glycol coolant. I'm just waiting for a price for TD5 hoses that are OAT compliant..... then again might go down the Evans Power Cool 180° (Waterless Engine Coolant) route http://www.evanscoolants.co.uk/Coolants/Pe...r_cool_180 Organic Acid Technology (OAT) Ethylene Glycol coolants usually contain compounds such as amines, phosphates, nitrites, borates and/or silicates. The mixture is far less environmentally friendly than a typical pure OAT coolant mix which usually contains none of the above. Hybrid (HOAT) coolants are generally moderately ‘silicated’ for improved aluminium protection.Ethylene glycol coolants offer rapid protection of cooling system components. However, the inhibitors deplete rapidly meaning that frequent changes of coolant are needed to maintain effectiveness. Typical coolant life can be 30 – 50,000 miles. Pure OAT coolants take longer to protect the metallic components in the system. However, once the protective layer is laid down, the inhibitors deplete only very slowly. Coolant life is typically between 150 – 300,000 miles. The initial cost of OAT coolants is also generally lower than that of ethylene glycol coolant. Cost savings can therefore be significant. Hybrid coolants (HOAT) offer a blend of the two benefits by using a moderate level of salts such as silicates or borates. The HOAT coolants offer rapid protection, long life (150,000 miles) and prevent clogging of water pumps etc. Traditional ethylene glycol coolants have little or no effect on hoses under normal working conditions. However, they can have an effect on certain types of reinforcement fabric used in the hoses. oat Summary LHSS - OAT Grade, offers an option between EPDM, blue coolant hose and fluoro-silicone hose, both from a cost and performance aspect.The construction of the OAT hose eliminates some of the potential failure points of a fluoro-lined and ‘standard’ blue hose while out performing EPDM hose.LHSS manufacture a high grade OAT resistant hose which also withstands much higher temperatures than conventional coolant hoses. Our OAT grade hose will operate in the range 150°C up to +230°C, making our OAT hose suitable for use in higher, under bonnet temperatures. Our OAT grade hose, also offers typically 30% higher burst pressure than standard coolant hoses. Silicone Coolant Hose OAT Resistant Silicone out performs conventional, organic hose materials, maintaining performance and flexibility over a wide temperature range, giving longer life and optimum reliability. Hand built and available in a range of sizes and Shore hardness, our hoses resists hardening, cold leakage, high and low temperatures, varying pressures and is manufactured to resist OAT coolants and additives. Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
You might want to take a read of this thread before committing to the Evans system
http://www.defender2.net/forum/topic63524.html?highlight=evans Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
A quick chat with the Evans waterless coolant people gave me the following response
There are no detrimental occurrences caused by using Evans with silicone hoses. Evans is widely used with silicone hoses by the majority of the race teams in championships such as Time Attack and Drifting to name a few. Also, the majority of the MXGP and MX2 teams throughout Europe use Evans with silicone hoses on their off-road motorcycles. The only thing that you need to be careful of is that Evans can be quite searching and if there's a way out, it will find it. However, it will seep out due to the lack of vapour pressure unlike with water-based fluid where it would spray/gush out, threfore you will need to ensure that the silicone hoses gain a good seal at the clips to avoid any seepage/leakage. Rubber hoses do inherently gain a better seal than silicone hoses. So new hoses, clips and waterless coolant it is! Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
My first thought is that they would say that
![]() I think you may have missed the point, though. Whilst the stuff clearly works for some applications, a Land Rover may not be one of them. Typical operating conditions are very different from any sort of racing machine, with different demands on the cooling system. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Just looked at the link you supplied. eek! perhaps not then
Back to OAT compatible hoses then A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
I could think of a few reasons why someone would want to use it in a race / trackday car. Not in a daily or a car prepared for travel. In that case I'd rather have normal coolant I can easily find on every street corner.
Got side tracked by the Wheeler Dealer episode where they put waterless coolant into a "normal" car ... sadly can't remember what it was ![]() Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Unless there is concrete evidence out there maybe from another forum member, I wouldn't bother. Complete waste of money and time in draining and prepping the system to take it. Would be interested in hearing what others views are especially from those that have actually used it!
I thought I would give it a try as I had/have the problem of overheating/limp mode when in 5th/6th gear going up a hill, but it is in a 2.4tdci and not a td5. Hasn't had any benefit whatsoever plus I didn't think through it hard enough. As the CHT sensor would register 115' and go into limp mode the actual temperature would only be 98'. I had read(from their marketing splurge) that as it doesn't boil it doesn't produce any hotspots which I thought was the problem with normal water based coolants. Got that wrong as well!! Just now waiting for the chance to drain all of it and replace with normal coolant. I for one will certainly not be using it again. |
triumph spitfire or stag
Good to hear from someone thats tried it and decided to revert to normal coolant. I've got a quote of £130 for all 3 TD5 OAT compatible hoses and in a selection of colours ... Given that paddocks quote £75 for the top hose and £75 for the bottom one thats not bad. A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I've switched to Prestone coolant. It's compatible with any vehicle and is just a standard coolant that mixes with water. I've had it in for about a year now, no problems at all
![]() The bonus is that it mixes with any other coolant so if you have residue left in the system or you need an emergency top up and can only get glycol or OAT it will be compatible ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5296 ![]() ![]() |
I ran evans waterless coolant, and I had nothing but problems with the engine. My mate who helped rebuild a Seat diesel engine had similar problems.
The car seemed to be under powered, like I was really forcing the engine to rev. We had a chat about it a few years ago and he got a link, Have a read of that ![]() http://www.norosion.com/evanstest.htm Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
“All system” coolant is a big no no in my book!
Td5s have enough leaking/hose/cooling problems without making it worse! ![]() Click image to enlarge |
