![]() | Home > In Car Electronics > Double din and extending cables |
| Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 409
Hi. I have done this but utilised a load of old switch bodies to suit the extension plug and then purchase new connectors of the correct colour and made the loom as required. It was quite a process and possibly over the top, it worked well for me. It all Allows me to place it back to stock if required in the future . An example is shown here
Click image to enlarge Hope that helps. |
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791
Personally I'd splice and solder them. Soldering in an automotive loom isn't the ideal solution, but several plug and sockets in free air will soon get very bulky!
| edo Member Since: 20 Aug 2018 Location: Devon Posts: 379
Thanks both.
I think I can get away with extending 2. I like the idea of a new connector with the male equivalent on the other end, but they dont exist or I'd have to make it up as you say. I have ordered some wire, heat shrink, and a soldering iron! One of the "click" switches no longer clicks and doesnt hold - are they fragile? Something has also gone wrong with heated seat on drivers side - switch is ok - if I plug the passenger in it lights up so that says the connector has gone bad? |
Good news, all done and quite neat if I say so myself.
The heated seat was just a fuse, and it turns out the heated front screen switch doesnt stay clicked it's a "press once for on, once for off" type. All good! |
| All times are GMT |
