Home > Maintenance & Modifications > New look grill and headlight surrounds on 90
johnnyd
Hi All, thinking about removing my A bar for a while to see if I prefer the look without, but the owner before me fitted additional spots on it, and has cut the grill to allow for the spot bowl, so I will need to replace the grill, maybe I should try a different look grill and headlight surrounds for a 'new look'. Any suggestions or pics of things people have done here, and any issues? I guess its pretty straightforward?
JD 2008 TDCi 2.4 XS CSW
Post #729186 16th Sep 2018 8:31am
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
In my opinion I think the OEM look is the best for your defender.
I f you have not done so change the headlamps to wipac crystals with uprated lamps and a headlamp relay.
This also improves the look of the Defender and also improves the lighting no end. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #729188 16th Sep 2018 8:48am
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
I would agree with above - the standard Defender grill is the best IMO. Replacement grill and headlight surrounds are available as a 3 part set on eBay for about £30 so much cheaper than a lot of aftermarket grills as well Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #729190 16th Sep 2018 8:59am
Martyn668
Original is best.
Post #729248 16th Sep 2018 2:56pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
The twisted style can look quite nice, when done right 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #729263 16th Sep 2018 4:15pm
johnnyd
Most of the grills I am seeing on ebay are black? Are they all black from new and need to be sprayed grey?
Post #729426 17th Sep 2018 8:16am
The Brunel grey ones were standard spec. on XS models. Darren
Post #729432 17th Sep 2018 8:42am
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
If you are after a Brunel grey grill and light surrounds I have a fairly new one I could sell you for £35 and am not far from Chippenham Very Happy
Post #729439 17th Sep 2018 9:03am
johnnyd
SOLD Smile
I'll PM you in a bit
Post #729453 17th Sep 2018 9:28am
Oakseywick
Thumbs Up
Post #729454 17th Sep 2018 9:33am
johnnyd
Like these MJN?
https://www.paddockspares.com/pm678-wipac-...ralia.html
There seem to be a lot of options on ebay LoL
JD
Post #729464 17th Sep 2018 10:15am
johnnyd
Both my surrounds look like this.....rather rusty
I am assuming that is not part of a new headlight purchase and is some sort of surround I need to order separately? I dont want to undo it to examine it as it might fall apart, is that what is holding the unit secure?
Post #729474 17th Sep 2018 10:45am
camelman
ciorrect, thats the retaining ring and wouldnt come with the replacement grilles or a new headlight.
they are only a few quid however and you can buy a new headlight bowl with the retaining ring for £12.
just google "defender headlight bowl"
Post #729476 17th Sep 2018 11:01am
You can also buy stainless versions of the rings (often called bezels) for around £30. Darren
Post #729477 17th Sep 2018 11:07am
hank
Yes I fitted stainless bezels to mine (black powder coated) - still like brand new.
Out of interest, what a bar are you thinking of removing? If a soft one I may be interested in taking it off your hands Whistle
Post #729481 17th Sep 2018 11:28am
