![]() | Home > Puma (Tdci) > Headlights coming on with no key in ignition. |
Is there an aftermarket loom fitted such as Boomslang or Land Reiziger? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17852 ![]() ![]() ![]() |
I seem to recall that the flash function works with no key in the ignition.
The flash on mine definitely works without the key.
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
sounds like there a issue with your stalk yes they flash high beam with no key but should not stay illuminated . I am not sure if they can be stripped down to clean a good spray with wd40 may help
stuckinmud Member Since: 23 Jan 2013 Location: monmouthshire Posts: 7 ![]() ![]() ![]() |
thanks for replies i have ordered a new stalk and see if that solves the problem. what i couldnt fathom was the random switching on and off when the vehicle was parked. I shouldnt be at all surprised to find an earwig or spider living in there!
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Did you check the headlight relay that activates the headlights only if the contact is on?
I had some issues with this relay in the past... Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
My guess is a contacts on the stalk is slightly contacting one another, possibly slightly bent or similar event.
Never knew that the flash worked with ignition off. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
Until the new switch arrives leave the switch in the "main" position while parked.
This will put a larger air gap between the "flash" contacts. Cheers, Kyle. |
SOLVED!
when i opened the steering column console up to replace the indicator stalk i was greeted with a cloud of smoke. one of the wires from one of the stalks in there was routed across the switch block for the main light stalk. All the wires exiting this switch block do so via a brass post to which the insulated wires are soldered. The posts are not insulated and are sharp enough to wear away the insulation on any wire that decides to sit above it. I made sure the wires were cable tied away from this switch block but it does seem remiss of land rover not to have put an insulated cover over this block. hope this helps anyone with similar issue. |
