Home > My Defender > Bit of a refresh |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 338 |
Dash looks bang on with the retrim
1st Sep 2018 9:31am |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
Looking forward to seeing how the rebuild develops. Cheers Don.
1st Sep 2018 3:31pm |
Shuggy110 Member Since: 25 Mar 2018 Location: Perthshire Posts: 58 |
Today I fitted some LED headlights, having resprayed the original cowlings. The driver side light was ropey, with intermitttent volts. I eventually worked out (via a strip of old wiring and relays) that the fuse box had corroded connections. All now replaced and redone.
8th Sep 2018 10:07pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
Nice one, good news with the electrical find 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
10th Sep 2018 8:34pm |
Good tip - thanks. |
13th Sep 2018 9:24pm |
Quick update for anyone interested.
Jobs done so far: Dash removed, holes filled and re-trimmed. Lower dash removed, holes filled and painted. Instrument pod (including metal case) replaced. Weird gauges removed and replaced with single clock - multi-instrument dash-top pod consigned to bin. New headlight switch fitted. DRLs wired up (the jury's out on them, but the 90 came with a DRL bumper). Wipac LEDs fitted. LED headlamps fitted. Dash indicator tell-tale replaced with Bolt On Bits LED one to stop all indicators coming on at once. Headlamp surrounds and grille re-sprayed. Rear X-member sprayed black (it was plain galvanised). Mud flaps fitted. Doors and bonnet removed. New doors currently being re-sprayed Keswick Green along with existing bonnet and wheel arches. Reversing light wired up (nothing was there other than the engine bay to rear lamp wire). MUD console fitted and wired up. Interior jetwashed ready for paint prep. Coil and plugs replaced - now running nicely. Next up - painting. Then steering box replacement. Then door re-build and re-fit. And roof re-fit. Then wheel refurb and tyre replacement. Then MoT! Then - maybe - steering wheel replacement Click image to enlarge |
13th Sep 2018 9:38pm |
Coming along nicely
14th Sep 2018 7:14pm |
Click image to enlarge Some Keswick Green - coat 1. |
14th Sep 2018 8:42pm |
i’d also like to replace the mats in both the front and the back. The back’s easy enough: it’s a 1985 Ninety hard top. The front’s more challenging. It is probably a 1985 footwell but the transmission tunnel suits an R380 with a V8. I know from previous experience that things are never quite the same when you put a V8 into what was previously a 10J engine. Does anyone have any advice about where to go for decent knowledge on replacement mats for non-standard vehicles? Sound deadening would be even better. I’m in Perthshire but would travel 200 miles for a quick and quality fitment.
Thanks. |
14th Sep 2018 9:43pm |
Sorry Simon - missed that in the heat of the moment. I bought this.... eBay Item No. 332790975103 |
14th Sep 2018 10:32pm |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 |
Cheers chap,
Will have a look at them. Great progress on yours, watching your thread and enjoying your updates. Simon |
15th Sep 2018 7:24am |
Unless you've physically altered the bulkhead, the floor mats are determined by the gearbox tunnel. If you've got an R380 'box tunnel, then R380 matts should be the ones to go for. As for sound proofing, there are lots of threads on here on the subject. Try a search for Silent Coat or Dynamat and you'll find lots of bedtime reading. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
15th Sep 2018 7:40am |
Click image to enlarge Thanks - photo below. Nothing on it is original. Does that look like an R380 tunnel? Click image to enlarge |
15th Sep 2018 9:44pm |
Hmm, no, that looks like an LT77 tunnel. It appears to be the same as my old 90:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
15th Sep 2018 10:09pm |
