![]() | Home > Puma (Tdci) > How much should a pair of drive members cost? |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
I recently (a couple of months ago) bought a Bearmach kit that included bolts and gaskets for just under £20. Genuine ones will undoubtedly be a lot more but I couldn't say by how much. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17817 ![]() ![]() ![]() |
Britpart or similar are about £5 each, other aftermarket brands from £7 to about £20 each, and genuine LR are £175.74 inc VAT each.
Ashcroft HD flanges are around £90 per pair and are better than genuine. Part no is RUC105200 if you want to Google. So if you got a pair of genuine flanges for £180 you perhaps got a bargain! ![]() |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
The cheap aftermarket ones are not worth fitting- I refused to because I don’t want to do it over.
Does the bill not break it down into parts and Labour? |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 687 ![]() ![]() ![]() |
That seems a bit steep - could they have fitted the single piece shafts like these?
https://www.ebay.co.uk/itm/LANDROVER-DEFEN...Swa3BbXweC |
I am sure that they could (assuming that it was the rear axle, of course) but those are £350 each inc VAT from a dealer.
blimbug Member Since: 17 Mar 2016 Location: Wiltshire Posts: 92 ![]() ![]() ![]() |
Thanks for all the responses.
It turns out they used genuine parts, hence the price difference vs. after market. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20879 ![]() ![]() |
The two best options really putting cost aside are Genuine 1piece which are the most pricey or two piece Ashcroft
HD and Ashcroft HD flanges. I don't see much point in cheap flanges, they'll just induce more wear more quickly on halfshafts splines which are considerably more expensive. Both options as Blackwolf above suggested to me originally will give you high mileage capability. Factory fitted two piece on mine lasted 60k which isn't bad though. Much depends on your use and miles, but they are quite costly even more so on the front. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
£180 is a shocking price when Ashcroft claim to sell genuine for £30
https://www.ashcroft-transmissions.co.uk/d...05200.html |
I would not be at all surprised if they aren't the same part. _\Hennessey|Venom| F5/___
