![]() | Home > 130 > 130 roll cage options |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2238 ![]() ![]() ![]() |
SD is the best imo.
Whitbred RAC Parts Coulple others I think |
JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 105 ![]() ![]() ![]() |
P&P (Protection and performance) do some nice cages. I've got an SD cage on mine but looked at the P&P option a while ago.
Picture from the P&P website ![]() |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 414 ![]() ![]() ![]() |
i went with SD internal rear cage. Lovin it...
Mcmuffin Member Since: 01 Apr 2014 Location: Antwerp city Posts: 38 ![]() ![]() ![]() |
![]() Click image to enlarge Our Safety Devices roll cage with internal hoop. Brand new fitted and tested Last edited by Mcmuffin on 4th Jan 2019 6:45pm. Edited 1 time in total |
lozza Member Since: 13 Oct 2016 Location: oxfordshire Posts: 190 ![]() |
nice
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18025 ![]() ![]() ![]() |
Very, very nice!
Thx. The roll cage proved itself at 1 overhanging tree. Next issue is fitting a tembo hardtop under the cage.
hi,we are doing the same or similar look forward to seeing pictures
loz |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Some pictures of the new setup Safety Devices roll cage second hand AFN hardtop second hand Roofrack, shortened so the rooftop tent fit together with the rack Last edited by Mcmuffin on 30th Mar 2020 8:47pm. Edited 1 time in total |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8476 ![]() ![]() ![]() |
sorry OT, how do you get on with the AFN canopy? Cheers
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2701 ![]() ![]() ![]() |
Check with your local Terrafirma stockist. If the SD cage is available centrally then you may get it within days.
P&P will have to build from scratch so will take longer. At the time I ordered my cage from Keith Gotts on the Tuesday and collected it on the Friday. Between myself and my brother we fitted it in three days (90 HT). Good luck |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
I had an Ifor canopy. Think AFN would be just the same for me. If you have to transport longer pieces once in a while it's a pain. Actually. Thinking about removing the normal canopy as well for that reason.
As in, does it leak, rattle, what's the build quality like? Would you buy another? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
When I bought the AFN, it was in terrible condition. Re-sprayed, re-sealed and re-fitted the doors now. Everything looks fine.
The fitting is no problem, just the usual issues with Defender : everything is a few mm too short, too long, not square...... At the end it looks fine, it is waterproof and it is bomb-proof. Next I will start organizing the interior. Pictures later |
