|  | Home > Off Topic > Wireless warning light |
| okami Member Since: 06 Apr 2017 Location: Hertfordshire Posts: 90      | I thought these were pretty common electric garage door options. I've had a few in the past that came with my garage door lift kits. Essentially just a mercury-type switch mounted to the door with a radio transponder that turns on/off a light plugged into the mains. The box plugged into the mains can also be configured to chime as well.
 The mercury switch is battery powered but lasts for several months (18-24 months). | ||
|  6th Sep 2018 8:08pm |
| Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808      | That’s exactly what I need but I can’t find anything online. Either a mercury/Reed/ptm switch could all be fitted. All I find online are the wireless WiFi stuff for the home or remote security lights. I’ll keep digging around ☹️ 2002 110 td5 | ||
|  6th Sep 2018 8:46pm |
| Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808      | https://www.amazon.co.uk/dp/B007Y7D8Z6/ref...KBbRW76TKT
 Could something like this be adapted to work? 2002 110 td5 | ||
|  6th Sep 2018 9:09pm |
| Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310      | You could use a Luminite Wireless Easy Switch here https://www.tlc-direct.co.uk/Main_Index/He...index.html if you fitted some kind of reed switch to the garage door, this would send a wireless signal to whatever device you need in the house be it a buzzer or a light. | ||
|  6th Sep 2018 9:27pm |
| ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777    | James, I'm sure I've seen an industrial door contact used to form a circuit which illuminated a light. If the contact was made when door open rather than closed could that work? | ||
|  7th Sep 2018 4:32pm |
| okami Member Since: 06 Apr 2017 Location: Hertfordshire Posts: 90      | https://www.amazon.co.uk/Chamberlain-829RE...B00EYYAKTY
 I believe mine are chamberlains as well but a different model. Came free with my lift units. | ||
|  7th Sep 2018 4:44pm |
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654      | James I had the very same problem. I bought and fitted a go go gate2 it sends a message to my smart phone when ever the door is opened and can be controlled from anywhere I have a signal.
 Best money I have ever spent. You do need to have a internet signal (Wi-Fi for it though) mines a stand alone garage away from the house so I burried a cable and set WiFi up in the garage) https://www.gogogate.com 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r | ||
|  8th Sep 2018 8:26am |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      | If your garage is on the same ring main (or shares some of it), you can use those power-link kits to give a resonably good network feed into the garage, save having to use wifi/exteders/burying cable | ||
|  8th Sep 2018 7:21pm |
| Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808      | Thanks for the suggestions everyone. I have decided to have a go at modifying one of these
   Click image to enlarge I will put switches in the open and closed position of the door and wire hem into the remote. 2002 110 td5 | ||
|  11th Sep 2018 5:29pm |
| Posting Rules
