Home > Puma (Tdci) > ABS Issue
Smithy
ABS Issue
The two ABS warning lights come on frequently for no reason,any ideas. Question
Post #728092 9th Sep 2018 3:26pm
dorsetsmith
do you have diagnostic trouble codes DTC from ABS unit Question be good place start help track down your problem
Post #728096 9th Sep 2018 4:12pm
NickMc
I doubt they’ve come on for no reason. Afraid you’ll have to get it plugged in to assertain the reason.
Post #728101 9th Sep 2018 4:42pm
Smithy
When I say no reason the ABS is till operating even though the the lights go on. This is an intermittent fault.
Post #728108 9th Sep 2018 5:36pm
NickMc
Could be anything you need to get the codes read to narrow it down- if the light is staying on it’s stored something!
Post #728113 9th Sep 2018 5:52pm
zsd-puma
As above really. We can throw random guesses at you until we've listed every component in the ABS system if you want, one of them will be correct? Laughing
Fault codes make it a lot easier though. Wink
All you can do without that is make a general inspection for obvious faults. ie Damaged wiring, loose wheel bearings, low brake fluid. And even then you may repair something, say a wheel bearing with excessive play and still not cure the ABS fault.
Post #728125 9th Sep 2018 7:37pm
dorsetsmith
first page of DTC and end page for ABS Whistle
Post #728131 9th Sep 2018 7:55pm
hank
Is the tracking ok on the front wheels? Front wheels free of play? These can cause wheels to rotate at different RPM which the sensors will pick up over distance and illuminate the ABS light.
Then it's just common sense, check the sensors are properly located fully down in their holes until the sensor shoulder is firmly home. Check connections etc.
You can also measure resistance across sensor terminals and compare the four sensors, see if one has a notably different reading compared with the other three.
If the problem persists your only option is to hook up to a diagnostic machine
Post #728216 10th Sep 2018 6:02am
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
I am with the same problem. My code is 17-03 Front left inlet valve short to grou
Can anybody help me ?
Post #728255 10th Sep 2018 10:50am
NickMc
Check wiring integrity, the solenoid is operating or if it’s shorted as the code says. You can download the wiring diagrams quite easily.
Lots of videos I’m sure on YouTube that will show you how to test an ABS solenoid Thumbs Up
Some problems with early Tdci valve blocks IIRC
Post #728349 10th Sep 2018 8:10pm
