![]() | Home > Td5 > CV joint mistake |
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926
I take it you mean the frc2310 the circular plate that rust's and bends slightly. Either way IMHO it's not the end of the world to leave it off. In fact on a CV job last week I junked it as it had almost rusted through, and had actually started to effect the stub axle by having holding the crud next to it. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
| Emptywallet Member Since: 03 Mar 2018 Location: Alresford Posts: 31
Yep thatâs the one. Itâs a mud shield apparently. Acts as a washer too, but as I loctited all the bolts I am not. Too worried.
Thanks for your reply. Will now enjoy another hour in bed as I donât have to get up and strip the whole thing down again! |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
It protects the inner seal and bearings on the hub I would fit it. How would you feel if you paid a garage to repair it and they left it out?
You are technically correct nick on that. In my findings it does naff all in stopping it getting in there and soon working it's way past the seals. if you are commonly in the cack all the time. It all but barely extends past the stub axle and there is still a fair gap to the hub.
Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
Get that washed you bad man!
For the 20 mins it would take to fit it I would. |
Not mine.....
This is what I commonly deal with when fixing the training vehicles. |
And no axle stand tut tut
Youâll always know you didnât fit it and in my mind it would torture me not being right. My least favourite to work on is Dog wagons the hair gets everywhere and in everything then gets turned inside a defender to moist clumpy muddy stink balls of hair Or pig farmers were the meal has grown into a maggot infested mound behind the seats Or sheep farmers with dirty needles hidden in all the nooks and crannies, but donât forget the dairy farmers - the smell of manure thatâs accumulated over many years ingrained in everything. Maybe I should start a channel 4 programme âHow clean is your Defenderâ |
Click image to enlarge Better? lol Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
Gravy
A lesson in water ingress: Click image to enlarge |
Click image to enlarge Wheel bearing failed - rounded the stubaxle and nut to dust, the wheel snapped the disk from the hub, then the wheel came free and wedged itself in the front of the arch. so did this one in the middle of the field. |
