Home > Maintenance & Modifications > Lower grill woes
stephan123
Lower grill woes
Hi,
The lower grille on MY15 Defender is looking worse for wear. Bought a replacement from Zunsport but unsure as how to remove the old grille. Any help would be much appreciated!
Post #728024 9th Sep 2018 8:49am
Bluest
You’ll need to drill out the rivets from the outside and either bolt or rivet the new one in. 2007 110 TDCi Station Wagon XS
Post #728025 9th Sep 2018 8:59am
JOW240725
As above, it is easy even I managed to do it! Good luck and photos please Thumbs Up James
Instagram @suffolk_rovers
Post #728026 9th Sep 2018 9:01am
stephan123
Thank you for the prompt replies. Never drilled rivets but will give it a go!
Post #728027 9th Sep 2018 9:09am
Balvaig
Use a new drill bit slightly smaller than the rivet head. It should fit nicely in the rivet "hollow". Go slowly/carefully with the back of the grill properly supported. Not too much pressure, let the drill do the work.
All being well the head of the rivet will come off and you should be able to push the remains through the hole.
It is always worth practising on a rivet in some scrap metal if you can,before you go for the real thing.
Not a difficult job.
Post #728032 9th Sep 2018 10:11am
JOW240725
You might also find it easier to take the whole grill surround off (screw across the top and one large screw on each side). Then you can drill them out in full view wherever easiest. Thumbs Up James
Post #728115 9th Sep 2018 6:09pm
discomog
As James says, take the whole grille off to make life easier. It's much easier to fix the new grille with machine screws and nuts rather than pop rivets an. of course much easier if you have to take it off in the future,
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #728233 10th Sep 2018 8:58am
edo
LR just painted the grille for me as part of my purchase. Was this silver or body colour from factory?
Post #728237 10th Sep 2018 9:27am
discomog
No it's a stainless steel one from Nakatanenga. Defender 90XS SW
Morgan Plus 8
Post #728242 10th Sep 2018 9:37am
edo
From the LR factory?
Post #728243 10th Sep 2018 9:43am
discomog
No, from 4x4 Overlander. Defender 90XS SW
Morgan Plus 8
Post #728244 10th Sep 2018 9:45am
edo
Ok sorry, to clarify, what I was asking, this grille is a painted section from the factory?
Mine was standard and in a right state (2013 car), it was as if the factory had painted the stainless and it had reacted.
Post #728246 10th Sep 2018 10:04am
From the factory, it's a silvery colour. I'm not sure what the coating is but it's rubbish and corrodes as soon as you look at it. Darren
Post #728248 10th Sep 2018 10:05am
edo
Ok, well mine is now body coloured so lets see how long that lasts!!
Post #728252 10th Sep 2018 10:26am
zsd-puma
It's very cheap Aluminium not stainless, that's why it doesn't last long, it corrodes and forces the paint off.
mine was body colour originally.
Post #728253 10th Sep 2018 10:42am
