![]() | Home > Technical > snorkel |
sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148 ![]() ![]() |
Hi All whats the best snorkel to fit to a Puma 2.32 2013 .Thanks
Steve |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
For actual wading or just for looks?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17874 ![]() ![]() ![]() |
The Nakatanenga one that uses the wingtop hole, in my opinion.
A quality product which massively improves engine breathing. |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Without a lot of faffing the nakatenenga one is the best. Like said above also opens up the airway for the engine.
Other options are the likes of safari/mantec/landrover. But all these will need the addition of pipework like the nugget stuff kit, also the snorkel would need sealing to the wing. Then seal the drain hole up in the airbox and fit extended breather pipes 👍 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
