![]() | Home > Maintenance & Modifications > Tips on CB Radio |
SJM, I've just got the midland 248XL great Rig..... don't know how to use it tho ![]() ![]() I'm sure the guys will put me in the right direction with it...too many buttons ![]() ![]() |
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 ![]() ![]() |
Good to know you're pleased so far though! What size aerial did you go for? Simon
'11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
I just got a cheapo one for now from Maplin just to play with it.... but Willy on here as got a decent one for me...i think it will be like anything else you get what you pay for
Did you fit it yourself? If so, how tricky is it? I have to warn you - I am a total numpty when it comes to anything electrical and I'm reasonably sure I'd blow my Defender up in the process of fitting it... I've looked for someone local who can fit it, and can't find anyone
![]() '11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
Yes i'm the same as you... so for now i got the cb with a cigarette socket fitted to it...just plug and play
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
breaker 1-9 this is rubber duck...do you have yourselves a convooooy
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
them Duke boys at it again!
![]() Pom |
karl dont sweat it re quality. for short range stuff anything will do.
Cheers Mike
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Harsh ![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
I couldnt resist ![]() |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I was thinking about putting my cb in and putting the arial on the front of my hard top behind the cab but would need a big length of cable would I lose a lot of signal power with a long run of cable
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Nah, use mini-RG8 cable, decent plugs with proper soldered connections... The loss in the cable will be minimal, definitely not noticeable to your ears.. The loss at 30mhz is about 2.3db per 100 feet of cable.. So, a relatively long run in a landy of say 20 feet is gonna give even less of a loss.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
