![]() | Home > Maintenance & Modifications > Snorkel benefits? |
| Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340
I did state that it came from the factory with it fitted, but they were determined that it wouldn't be covered if it was on the options list. Something about the vehicle being used for "extreme offroading"
Funny thing is they never mentioned the factory fitted "optional" winch or roll cage being a problem... or that it had a massive set of bull bars that they were only too happy to cover Who knows what would happen if you didn't mention it then had an accident though, we all know how they like to use any loop hole possible not to pay out The flip side is that my Subaru is extremely cheap to insure as it a "standard" car - despite having almost every performance toy and power upgrade available from then World Rally team at Prodrive - because that's how it was sold at the showroom. The only modification I've had to tell them about is the different exhaust |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
Thanks for all the responses, really helpful.
| smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233
From a personal experience, I would leave it on, but change the ducting inside the wing to Nugget Stuff and remove the impeller.
Main reason being when you remove it you may not like what you see regarding the holes in the wing and the windscreen pillar that it will leave and also the damage to the paintwork where it will have been rubbing. I had the original RAI as supplied by LR at new. Changed it to a Safari Snorkel with Nugget Stuff ducting as I felt I had a better chance of sealing it from water ingress. What I found when I removed the original was a disgrace as they made a bit of a cock-up in drilling the holes, the seals weren't installed correctly and the body flexing caused the RAI body to rub against the wing which rubbed the paint down to bear metal. The Safari has a different fixing footprint so I was left with unsightly paintwork damage, but thankfully the holes were covered out of sight which if you remove it completely you will either 1/ have to put up with it, 2/ find something to completely cover it up or 3/ replace the wing/repair and spray the wing. Then you have the holes in the A-Pillar which will be the same as the wing situation. |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
My Td5 was more responsive after i fitted the snorkel. The Safari one i fitted was the older 300tdi/TD5 one with the ducting that replaces the standard wing intake. which i would imagine is the most restrictive part of the air inlet system. You dont get this advantage with the TD5/TDCI safari version which retains the standard wing inlet.
I personally wouldnt want to remove the inlet impeller on the airbox as this helps to seperate the water droplets from the incoming air which would end up wetting the airfilter. With the safari inlet facing forward after motorway driving in very heavy rain there is noticable moisture in the bottom of the airbox. Steve 02' 110 TD5 Double Cab Rebuild Thread |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
That's why you just ask "do you need to know about manufacturer fitted accessories?". Don't get into detail about what they actually are. When they say 'no we don't' then you're covered if they try and argue the case later on. Something as simple as alloys for example can be a nightmare if you tell them it has 'optional' alloys on it, because they'll tick the modification box for wheels and put the premium up, even though most cars have a choice for half a dozen different wheels when you order the car from new. Just don't over think it. Most insurance call handlers are quite poorly trained, being too detailed just confuses them. |
| Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 951
My td5 has a safari one fitted from when I bought it but I would rather not have it! However I have the same dilemma about removing because of the repair work to the wing etc required after which is annoying!
Mike |
If its just a question of hiding the two nutserts left when removing the factory intake, then they could just have a couple of dome head stainless screws put into them. Given that the Defender has exposed screws and rivets all over it I don't think they would look out of place. Only an enthusiast would know they weren't standard.
That's a good point but the safari required 3 large holes in the wing around the intake. However I would be happy with just putting small screws on the windscreen pillar though to block those small holes. The wing holes are the main problem anyone removing a safari will be faced with.
Best thing is just to take it off and see whether you would be prepared to put up with seeing blanked off holes and damaged paintwork(you may be lucky and they have fitted it correctly thereby limiting the paintwork damage). There is also a chance of the paint bubbling around where the holes were drilled and flaking off.
If you do remove it you will need to install the side vent anyway so you may be able to find someone that could make a backing plate of a size that could cover the same footprint of the RAI. That may be a better solution. Good luck |
That backing plate could be a good idea, thanks
Thanks all, great info.
Evem M8 threads would only have about a 12mm diameter head, domed cap head screws still wouldn't look out of place. and of could you could just paint them body colour after fitting with a paint pencil. |
This is true, not quite a big issue as I originally thought, thanks for the suggestions
