Home > Puma (Tdci) > Engine lift bracket
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Engine lift bracket
Just completed a 1000mile road trip during which I could near a metallic rattle when pulling hard uphill mostly. Searched for anything loose whilst away but now back home had a proper route around and found this nestled comfortably on the rear of the engine............the bit that’s left in is still tightly bolted in place.....flipping really flipping flipping flipping should this happen?!!!!!?
Post #726637 1st Sep 2018 2:15pm
zsd-puma
it's supposed to be removed on the production line once they'd fitted the engine/gearbox assembly or by the dealer during PDI.
There was a TSB about it, where during routine servicing dealers were supposed to check to see if one was still there and bin it if it was. It risked rubbing through a couple of hoses I think.
Post #726642 1st Sep 2018 2:48pm
Blimey, I'm surprised that there are any of those still left in place. Just remove the remaining bit and throw the whole lot away. Darren
Post #726644 1st Sep 2018 2:49pm
zsd-puma
looking more closely at the pic, I expect someone (probably in a dealership) tried to remove it but the bottom bolt was stuck so they just took the top one out and then rotated it out of the way, at which point the vibration has gradually fatigued the metal.
Post #726647 1st Sep 2018 2:59pm
Mine's still fitted and causes no problems at all (2007 Defender, 226k miles).
Post #726648 1st Sep 2018 3:04pm
williamthedog
They must have been good fellows with mine and removed it 😁😁😁
Post #726665 1st Sep 2018 4:47pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Mine was left attached, and wore a hole in the cabin heater pipe.. Take it off, and bin it.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #727218 4th Sep 2018 11:59pm
You'll regret taking it off when you need to lift the engine out.
A better bet is to make sure that it is bolted on properly and that no pipes or harnesses are chafing on it.
Post #727242 5th Sep 2018 8:30am
dorsetsmith
At Β£50 to replace the per then at too days price Exclamation
Post #727249 5th Sep 2018 9:27am
zsd-puma
can always take it off and lob it in with your tools/back of garage. It's not as if putting it back on would massively extend engine removal time. Or that you'd need it at the roadside.
Post #727262 5th Sep 2018 10:05am
