![]() | Home > Td5 > TD5 Non Start |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Click image to enlarge |
there is feed going through the starter relay. ? and will not the engine turning over on the starter motor.
| Td5Cam Member Since: 09 Apr 2016 Location: Somerset Posts: 32 |
Correct, nothing happens just have the amber fog lamp dispmay on the dash which i dont understand...
wrong diagram
Yes there is a feed going through the starter relay and through to the starter motor itself
This is what i see when i turn ignition on
Click image to enlarge The EML and Coil lights extinguish and the just left with the fog lamp on Click image to enlarge |
you have pre 2000 TD5
Its 1999
ok that changes things diagrams fuse box and relay lay out
The EML lamp extinguish on start up to test the light and Coil lights extinguish glow plug time out
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
As there is no oil pressure, handbrake warning or charge warning light there is definately some things not getting power. When you stalled it was it quite a violent stall? It may have unplugged something in the loom... 2002 90 Td5 Station Wagon
If i leave the ignition on the warning lamps do come on after some time, but if you then go to turn it over you can hear the starter motor engage but then nothing just back to square one with no warning lamps again.
The stall wasnt particularly violent no. |
If there is a feed going through the starter relay, does that necessarily mean that there should be a feed going through the main relay? Just wondering if maybe its the main relay at fault because there is no fuel pump sound or the normal warning lamps to be expected from ignition
