![]() | Home > Technical > puma dead when turning on |
| Noiseydave Member Since: 27 Dec 2015 Location: West Midlands Posts: 43
Had similar, turned out to be ignition switch and wiring to it. Repced switch and all has been good since. I also suggest you check the earths
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067
Battery connections ?
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Battery connections being loose will do that as mentioned by Daz above.
Check the easiest things first, check the Rekays are secure under the drivers seat also. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| rillas Member Since: 27 May 2012 Location: warilla nsw 2528 Posts: 16
thanks
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
I've had a similar issue that was due to one of the under seat relays getting loose. I had to tighten up the terminals in the end but it's been fine since.
