Home > Tdi > rads
Procta
rads
What is the best ones to go for? I am toying with three types, an Alu one, a standard one and an army one
the place the did the mot recon I should go for a standard one, But my 306 has an alu one which is nearly 20 years old.
not sure what a military one is like or any different. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #725144 24th Aug 2018 1:14am
Retroanaconda
Brass/copper over aluminium/plastic every time.
Post #725313 24th Aug 2018 10:17pm
oneten110
On the pre WOLF diesels, the radiator was the same as the standard civilian spec item
Post #725348 25th Aug 2018 3:32pm
white110
Wales 1997 Defender 110 300 Tdi HT Alaska White
The plastic/aluminium is rubbish, I was looking for a leak and in pulling the top hose to see if it was that, broke the whole flange off, the plastic tore down like wet paper. Took it back to the Green box supplier, who shrugged and I got a small discount on the copper one.
Post #725361 25th Aug 2018 6:22pm
yostumpy
recently replaced my 'transparent' rad, presumably 20 years old, with a Bearmach copper sided one, from Island 4x4, good price, very quick delivery.
BEARMACH (BTP2275 BM £210 deliverd
Post #725377 25th Aug 2018 8:20pm
Alex1976
I have had a fully aluminium rad on my 300tdi Defender for the last 3 years and it still looks like new and performs well. No overheating issues at all, if anything it seems to help it run cooler.
I got it on eBay for £120 - it is a made in China job, but the welding all seems good and it’s a solid item, three years on no issues, so I am happy.
Post #725395 26th Aug 2018 12:58am
Procta
What else do you lads recon I should replace while the system is drained off? Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #725712 27th Aug 2018 9:03pm
You might as well replace all of the rubber hoses and clips. Darren
Post #725716 27th Aug 2018 9:09pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
I did the same as Alex above - no problems. As for replacing other parts, I wouldn't touch anything unless you are having any sort of overheating issues or if your P-gasket is showing signs of leaking. I would refill with fresh water and antifreeze if the old coolant looks murky as you wouldn't want to gum up that shiny new rad straight away Thumbs Up Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #725717 27th Aug 2018 9:14pm
Procta
looking for a copper one, they seem to have been replaced with alu rads? looking on ebay Rolling Eyes Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #726815 2nd Sep 2018 7:57pm
Procta
I am looking at flushing the system through, as I do have some sort of crap in the expansion tank. I hope to Christ its not signs of Head gasket failure, looks like the same as I rover metro. Shocked Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #726824 2nd Sep 2018 8:31pm
Retroanaconda
Forget eBay. Find your loca auto radiator place, they’ll be able to make you one.
Post #726900 3rd Sep 2018 7:52am
Procta
I managed to bell my local parts discount and he said they maybe able to get it re vamped again.
My local auto rad place shut down about 15 years ago, the place is flattened and a block of flats are on there now. Sunderland is a bit of a dive with this sort of thing, not sure if even newcastle has a place now either! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #726950 3rd Sep 2018 1:13pm
Retroanaconda
https://www.adrad.co.uk/
These guys seem to be in Newcastle, and list Defender radiators. Worth a look certainly.
Post #726964 3rd Sep 2018 1:53pm
