![]() | Home > Maintenance & Modifications > Broken Headlight |
or new lens and
Acrylic Headlight Guards STC7561 |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
Good point
I'll check them out, thanks |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Why dont you put the wipac crystals on. Plastic lens, better than the standard headlights. Put nightbreaker bulbs in and your sorted
![]() Whilst you're there you could fit stainless steel bezels as well. |
Got stainless bezels sat waiting
![]() Will check those out too ![]() |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
+1 for williamthedog's suggestion
![]() Click image to enlarge With a boomslang loom they're bright even in daylight. |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 462 ![]() ![]() |
Hi,
Are these a direct swap over, or is there any rewiring to do? Cheers all. |
Easy direct swap - but as suggested above rusty bezels (the ring that holds the light unit to the headlamp bowl) can be a problem.
This is a good guide https://www.landyzone.co.uk/land-rover/headlight-renewal.130728/ ![]() |
![]() I have replaced the bezels with the stainless ones, so I will look into this. Cheers mate. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
If you change the bezels to SS get the SS fixing kit too.
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
The standard wipac ones are cheap, they fitted the same ones (with a side light) on the mini, In 20 years and just shy of 100'000 miles I've only broken one on my mini.
I think you're just unlucky to break one. |
I've had six Defenders without a windscreen or headlight needing replacing,
Number 7 and although my favourite it will of had both. Lucky Defender parts are cheap to replace 👍 |
New headlight on and stainless surrounds fitted
I must say I prefer black surrounds so might get another set and get them painted. |
Which headlights did you get after?
I just replaced the one with standard wipac unit from Duckworths
For now. |
