Home > Puma (Tdci) > Leaking fuel tank
ChrisDefender
Leaking fuel tank
Hi chaps,
My 90 has just failed its MOT on a leaking fuel tank. It seems to be coming from the top fro what I can see without further investigation, so I am hoping its just some seals? Is there anything obvious I shoul dbe looking for, or if I have to replace the tank is there any suggestions on the best one to go for?
Any help for a beginner very much appreciated! Bow down
Its a 2010 Puma 90 HT.
Cheers.
Post #720871 1st Aug 2018 6:43pm
dorsetsmith
have read below
http://www.defender2.net/forum/topic22296-135.html
http://www.defender2.net/forum/topic40466....+fuel+tank
Post #720877 1st Aug 2018 7:14pm
dailysleaze
If it's going down the right hand side then it'll likely be the breather pipe. See here http://www.defender2.net/forum/topic25866.html
If it's coming down the front then may be the seal for the fuel pump or the pipe to pump fittings. The plastic tanks themselves don't really leak.
Post #720878 1st Aug 2018 7:15pm
ChrisDefender
Cheers guys,
I hope its the pipes then as it looks to be a bit of a job to get the tank out! and way out of my league. Big Cry
Ill let you know how I get on.
Many thanks again Bow down
Post #720884 1st Aug 2018 7:51pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Cutting a hole in the floor might be the way to fix the fuel leak on your 90 if it’s the pipe work:
Post #720889 1st Aug 2018 8:08pm
DAZ110
Post #720892 1st Aug 2018 8:15pm
ChrisDefender
Hi,
Thank you very much for the info. I will take a read through it all and get onto it.
Cheers all,
Chris
Post #721072 2nd Aug 2018 4:27pm
ChrisDefender
Thanks for all the replies chaps. It was the breather pipe. New one on, as well as new clips on the main pipe and all seems good.
Cheers.
Post #724644 21st Aug 2018 6:54pm
DAZ110
Thumbs Up
Did you take the tank out to fix it?
Post #724646 21st Aug 2018 7:02pm
ChrisDefender
Hi,
It was my local indy who did it for me, they have defenders so know a thing or two. It was all down the right hand side, the top of the tank was all dry and OK.
They did drop the tank out, and changed the breather pipe and also the main filler pipe too whilst they were in there. Also gave me a chance to rust proof the floor above the tank and rust proof and re paint the supporting tray, so all in all a good job.
Cheers.
Post #724841 22nd Aug 2018 4:13pm
DAZ110
Thumbs Up
Post #724856 22nd Aug 2018 5:14pm
