![]() | Home > In Car Electronics > C Tek recommendations |
| Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223
I have a CTEK 7.0 and keep it plugged on through a live 'cigarette'` lighter point all the time, as I do on all our modern cars.
It guarantees a good battery and CTEK have never let me down in years of using their products Thoroughly recommend. 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
| discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543
I've had a couple of MXS 5.0 chargers for a number of years without problems. The problem with the XS 0.8 is that it is only a trickle charger and therefore not as versatile as the 5.0. If you ever need to charge a battery overnight in an emergency then you'll not achieve it with the 0.8. I know there's a large difference in price but I think if you only have one Ctek in your garage then it should be the 5.0 Defender 90XS SW
| Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357
Thanks for the replies, it's not so much the price as I only want to buy once, but don't want to buy something oversized and physically larger than necessary for installing.
Looks like the MXS 5 is the way to go so far. Thanks Keith |
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
Hi there,
I have both chargers. There is little difference in physical size. I do not think the 0.8 would cope with a flat battery larger than the motorcycle size battery. It is more a trickle charger for larger batteries. Would recommend you get the 5.0 as it is far more versatile and would meet your needs. |
| TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 241
I have the MXS 10 £100 from Halfords when they have them on offer. I have it connected to a towing connector so that I can just plug it straight into the back of the 90 when its in the garage without any fuss
Cant fault it, although it can be frustrating if you need to charge a particularly flat battery. |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
The MXS 5.0 has a button giving you the choice to charge at 5Ah, or at only 0.8Ah. So with that one the charging speed is at your choice.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
I have a couple of MXS 5 chargers which are ideal for Defenders and similar sized batteries, and also an MXS 25 which I use for the humongous battery on my mobile crane. The latter would be massive overkill on a Defender battery but is ideal for a battery the size of a horse-trough.
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791
I have an mxs5, perfect for general use! Also have an older xs7000 which is good for slightly faster charging.
Once my split charge is in I plan to replace my 7 pin socket with a 13pin, then will make a ctek to 13 pin adapter to go with it |
| Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1696
ive ran a ctek 7000 for many years on my weekend motor.
the smaller one isn't man enough charge a agm battery.if you look on their webpage there are recommendations galore. https://www.optimabatteries.com/en-us/supp...rging-tips |
MXS 5.0 ordered.
Thanks Keith |
| All times are GMT |
