Home > Technical > X ENG disc handbrake - impulse purchase
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Hi, just picked up a complete 2nd hand disc handbrake conversion on EBAY, is there a difference and if so what ? between the Disco and Defender kits. Had a quick look on the website and it lists them separately. Bit puzzled as when I fitted a Disco transfer box I don't remember having to change the cable. Any wise words would be greatly appreciated.
Post #724465 20th Aug 2018 8:52pm
jst
i think its just the actuation of the mech that varies, you need an early (side mounted mech) cable to operate a disc brake Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #724518 21st Aug 2018 8:33am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
From memory some of the bracketry is different as well. On a defender the caliper sits near the top but is on the side on a disco due to clearance on the transmission tunnel. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #724536 21st Aug 2018 11:16am
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
For the discovery version the calliper sits at the 9 o'clock position and the defender one is the 12 o'clock position.
I think the defender version had a better cable clamp also, which spans the two bolts that hold the calliper. The disco uses an 'L' shape tab locating on one hole which is prone to moving when applying the hand brake.
Post #724540 21st Aug 2018 11:48am
jst
that is right now you mention it i forgot.
defender one sits at 11oclock. disco one closer to 9. you can always redrill the mounting holes on the caliper bracket to re position. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #724542 21st Aug 2018 11:55am
Moneypit
Was only £80 so not to concerned, once I pick it up on Friday I'll have a look and decide if I'm going to use it or not. Thanks to all for your help.
Post #724638 21st Aug 2018 6:41pm
I'd try and stick the pads into the caliper with silicone as well... mine used to rattle a lot, in the end I swapped it for a standard unit as I got so fed up with it.
Post #724684 21st Aug 2018 9:23pm
Harry.O
Similar rattling issues with mine. I've mounted it numerous times with plenty of grease on the sliding bolts following the instructions to a T and whilst better, I still get a rattle/cheep-cheep noise from it. I found silicone didn't last too long and the pads are now held in with tigerseal but it's easy enough to remove them with a sharp knife. I'm deliberating about going back to standard, just because the noise annoys me Sad 2005 Td5 110 Hardtop
Post #724786 22nd Aug 2018 12:10pm
donmacn
just FWIW, I've had mine on the car for so long now that I can't remember when it was fitted. It was a 'quick fix' to the OE brake which was 'catching' as the car slowed for traffic lights etc.
I think I did have rattling noises to start with, and I think I did silicone the pads into place - or at least used something in there. Now though, it's been completely silent for years and just works... absolutely trouble-free. When I say years, I mean comfortably 10+. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #724788 22nd Aug 2018 12:18pm
smb
When the X-Eng Brake was released by Simon he did add to the fitting instructions that if a rattle occurs then try and use some silicone to hold the pads in place. Mine rattled initially so gave it a try and its been noise free for about 5years Thumbs Up
Post #724796 22nd Aug 2018 1:40pm
jst
if anyone has one they wish to sell i am looking for one. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #724902 22nd Aug 2018 8:21pm
