Home > Expedition & Overland > Which Gas?
Mr Baldylocks
United Kingdom 2002 Defender 90 Td5 CSW Bonatti Grey
Which Gas?
Hi Guys
We’re starting to put things together so we can use the 90 for camping and LHG wants to know what gas are people using for cooking? We intend to use a set up on the back door but if it’s raining then maybe inside but do we use Propane or Butane? Thanks for your help and any tips that you might have👍 Life is one big adventure, that's why we have the vehicle for the journey.
Post #724261 19th Aug 2018 6:45pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
If you anticipate using the setup in winter then propane, otherwise butane. Butane burns hotter but is reluctant to come out of the cylinder at much below 5C. Propane can be used at much lower temperatures. http://www.yorkshireoffroadclub.net/
Post #724290 19th Aug 2018 9:27pm
Mr Baldylocks
Thanks davew👍 Life is one big adventure, that's why we have the vehicle for the journey.
Post #724313 19th Aug 2018 10:28pm
miker
I use a little jetboil type stove for lightweight camping, with whatever fancy isobutane mix is needed.
For overlanding I'd go petrol... It's what we use when we're heading further afield as it's easy to get hold of almost anywhere!
Post #724327 20th Aug 2018 9:34am
MartinK
I use Petrol (an MSR stove) when climbing in the Alps. Gas has much lower pressure/propulsion in the cold (minus 10) temperatures... The old blue "Camping Gaz" stuff won;t boil a kettle under these circumstances... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #724335 20th Aug 2018 11:05am
