Home > Maintenance & Modifications > Puma front pads and discs
Page 2 of 2 <12
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Thanks for your help all, new parts ordered from Paddocks this evening.
Just need to get a set of axle stands and some time in the diary to get it fitted. Keith
Post #723690 15th Aug 2018 10:55pm
The Sealey 3T each 6T a pair are pretty good. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #723694 15th Aug 2018 11:18pm
Procta
a little Trick, if you have an old spare steel wheel, take that off and place the hub in there so that you can wind off the disc. basically you are using the wheel as a jig for the hub, makes tapping in the bearings easier too, as the wheel is flat Thumbs Up
My dad loved it, as he used to have a little trouble with getting bearings back in, If you don't have a steel wheel, then id just buy on off ebay, just to use as a jig. Thumbs Up
I kept my old spare wheel for this purpose Smile Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #723698 16th Aug 2018 12:56am
Keith5
Another quick question, possibly not the last, does anybody know the part no for the bolts you need to replace. Or alternatively the dimensions and material.
Thanks Keith
Post #724198 19th Aug 2018 8:55am
dorsetsmith
https://www.landroverworkshop.com/diagrams...iscs_44959
Front Brake Caliper Bolts Qty 4 SYP500090
Front brake disc to hub Bolts Qty 10 UYG500030
and two RFD100000 if you sticking with as built
Post #724204 19th Aug 2018 10:40am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Having changed disc's on several Range Rovers, Disco and Land Rovers over the last 30 plus years the only advice I can give to add to what's been said already is :-
Make sure you get the correct part, some sellers don't know that there is a difference on some models, from a reputable company.
Invest in a hide or soft face hammer to prevent damage to the new disc ,I have seen them shatter if a metal hammer is used.
Make sure you get the new disc on square to the axel and don't rely on pulling it square with the bolts as a new one can jam and the bolts feel tight. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #724329 20th Aug 2018 10:02am
Keith5
Do I need to torque the hub nuts when I put it all back together? Assuming I do but how do you do that with the box spanner?
Thanks
Keith Keith
Post #727622 6th Sep 2018 7:13pm
Siwynne
Does anybody have the wear limit measurements or tolerances for 110 Puma front discs. I do a fair few miles but may only touch the brakes ten times on a 25 mile commute. I don’t want to change them if they’ve got loads of life in them. Current ones have done about 40000 very gentle miles as have the pads with lots of life in them.
Post #781326 13th Jul 2019 10:42am
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
The Haynes manual says, Brake disk pad thickness 3mm. That's how it's written so i assume it means disks and pads.Your disks should be fine after only 40k if not abused. 130 crew cab
98 V8 Disco
Post #781334 13th Jul 2019 11:53am
Hal
Thanks
Keith
Use one of these https://www.lrparts.net/hub-nut-socket-52m...-jobs.html
/Hal
Post #781353 13th Jul 2019 5:11pm
ericvv
Front disks thickness new 24 mm, minimum allowed 22 mm. Same numbers for rear disks are respectively 16.1 mm and 14.1 mm.
Took the numbers from the certificate my dealer had to issue for the Swiss MOT this week. The measured thickness on my 110 after 101.000 km which is still on its original factory disks was 22.6 mm front and 15.2 mm rear, so still well within spec.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #781357 13th Jul 2019 5:44pm
Siwynne
Thanks
That’s exactly what I’m looking for
Post #781359 13th Jul 2019 5:53pm
Page 2 of 2 <12
