Home > Maintenance & Modifications > Heater switch light flickers on / off easy fix. Puma? |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
"custom90steve" docet !
http://www.defender2.net/forum/topic16996.html Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
16th Aug 2018 10:40am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19624 |
Justgo very easy with the bulbs and don't put too much pressure on them.
A drinking straw may do the job too if you can find the right size. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
16th Aug 2018 11:20am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3696 |
^ Great
Will have a look and print this out, |
16th Aug 2018 11:47am |
a couple of bits of rubber hose pushed over some circlip pliers works well. But so long as they're not hot you can normally pull them out with your fingers.
16th Aug 2018 3:03pm |
Sorted, long nose pliers and masking tape on the end... 5 min job it works. Its been iffy for ages !!! Click image to enlarge thanks |
17th Aug 2018 11:39am |
17th Aug 2018 11:42am |
Mwd Member Since: 12 Jan 2016 Location: Scottish Highlands Posts: 44 |
How do you get the front of the instrument panel off? I've removed the two torx screws but it still seems firmly attached and I'm reluctant to try prising it off in case I break something expensive!
24th Sep 2018 8:12pm |
take the radio out, remove the two torx screws then give it a good pull. (it's retained by some spring clips.)
24th Sep 2018 9:49pm |
Just sorted mine - thank you for the helpful advice. Three out of four bulbs had blown (after Β£70k miles / 6 years) and weβre replaced so the controls should be easier to find at night now!
25th Sep 2018 4:50pm |
