![]() | Home > Puma (Tdci) > DPF or gearbox cabin heat |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I put some of the foil covered sound deadening on the underside of the cover under the cubby box, it doesn't get hot in there anymore.
You can do the same to the gearbox tunnel if you want. You can just get the self adhesive foil on it's own will do the same thing in terms of temperature control. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
My 2.4 became noticeably cooler in the cabin when I removed the cat. Another interesting characteristic is that if you have any of the windows open you get much more heat in the footwells, and the only explanation I can come up with for this is that with the window open air is drawn from the cabin allowing hot air from the transmission area to be sucked in through the characteristic incredibly well-sealed Landrover floor.
The floor in the vicinity of the transmission certainly will get too hot to touch and could be contributing to your heat problem, but I imagine that the DPF must be a very significant heat source, hotter and larger than the 2.4's cat. |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 620 ![]() ![]() |
The floor and handbrake of my 2.2 became really hot on a long run. I drove 740 miles in one go with only a stop for Dover Calais ferry and Fuel. I did it barefoot and at one point I had to put my left foot on the plastic handle on the handbrake because the floor was so hot. As it cooled off in the evening and we slowed through Paris it all cooled significantly. I just put it down to exhaust and dpf in 40plus degrees.
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
remove centre silencer replace with a straight through pipe this reduces weight and heat with little change in noise levels and isn't illegal like removing the CAT, just be careful what you buy they are not all a good fit. DEFENDER 90 TDCI XS,
I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 16th Aug 2018 7:50pm. Edited 1 time in total |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3501 ![]() ![]() ![]() |
I think my local MOT tester will have a field day when I tell him I removed the DPF for heat reasons.... 1951 80" S1 2.0
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
I suppose it is the cat/dpf creating the heat, however I notice when driving in cold e.g. sub zero weather that the area down the sides of the seats (between them and the cubby) gets really cold, so much so I tend to stuff a jumper or similar down there.
Point being, clearly that area is poorly insulated. 2014 Keswick Utility 2.2 |
